Engine paint color?
Old Jun 20, 2007 | 10:17 AM
John inNH's Avatar
Engine paint color?
Hi all. I just pulled off the carb from my '75 Cutlass for a rebuild, and figured I would repaint the intake while I could get at it. Unfortunately, I can't find the correct engine paint anywhere. Its a metallic blue color, definately not GM Corporate blue, and nobody seems to have it listed. Any ideas?
John
Old Jun 20, 2007 | 11:44 AM
John
www.fusick.com
Old Jun 20, 2007 | 07:34 PM
John inNH's Avatar
Still no luck.
Thanks for the link Joe, I see several items I'm going to order. Unfortunately, the only blue color they list is for 70-72 455's. Any other ideas?
John
Old Jun 20, 2007 | 08:01 PM
John
As far as I know, all 70-75 455s used the same metallic blue. Be aware, however, that the paint is very sensitive to application technique. If you apply it in several thin coats, it will be light and silvery. If you apply it in thick wet coats it will be more blue and less metallic.
Old Jun 21, 2007 | 06:53 AM
John inNH's Avatar
Engine paint
Hi Joe,
I probably should have mentioned that its a 350 olds motor, not a 455. I'll probably order the paint anyway, as it sounds like the only one thats close.
John
RAMBOW
Dec 7, 2017 07:22 PM
jvock6
Apr 30, 2012 10:31 PM
69442
Dec 10, 2009 06:40 AM
gforcecuda@gmail.com
Nov 17, 2008 01:47 PM
dynamic88
Oct 26, 2008 06:55 PM
