Bucket Seat Conversion
Old Feb 7, 2009 | 10:47 PM
scott_442's Avatar
It's been a good weekend so far...just picked up these seats locally for the paltry sum of $40...they're not perfect but can't beat the price! What is needed to do the conversion? I know there are some brackets that have to be bought. How do those line up? Do the seat belt retractors have to be moved? Has anybody ever documented this process? Any pitfalls to be aware of? thanks!!
Old Feb 8, 2009 | 02:54 AM
Bluevista's Avatar
Registered
Good deal on those seats.
I was thinking of putting buckets in my Vista and found these instructions and pics on how to do the floor mounts in a '71 El Camino. It's being done at Hinshaw's Chevelle and he also sells all the parts. A little bit of welding and about 3 hours time is all he says it takes.
It is in an Adobe PDF file format if that matters.
http://macc.chevelles.net/buckets_install.pdf
Old Feb 8, 2009 | 05:04 AM
71rocket's Avatar
car nut farmer
Wish I had buckets. But then I'd need the console, linkage, different steering column ............... well you know the rest.
Old Feb 8, 2009 | 06:08 AM
I've got an extra steering column, if anyone needs it.[non tilt] for a console car.
Old Feb 8, 2009 | 07:46 AM
KZ442's Avatar
Hi Scott 442,
I am in the process of putting buckets and a dual gate in my 72 442. If you get the assembly manual for your cutlass it will also give you the measurements for the shifter either standard or dual gate shifter. I paid $25 for the assembly manual and it was the best $25 I ever spent for info.
Old Feb 8, 2009 | 07:48 AM
KZ442's Avatar
Steering Column
Hi Jamesbo,
What year is the column out of?
Old Feb 8, 2009 | 08:10 AM
69+ I
I'll have to look when I get home. No wait, I never owned anything but a 69 so It's a 69 unless some one put a different one in one of my 69's before I bought it. [not likely]
Old Feb 8, 2009 | 08:30 AM
KZ442's Avatar
Column
Thanks Jamesbo,
How much are you asking?
Old Feb 8, 2009 | 08:34 AM
How about nothing
Free
That way you won't yell at me if something is missing or a rat ate a wire or two.
Old Feb 8, 2009 | 09:09 AM
KZ442's Avatar
Column
That works for me, I just need the shifter bowl to convert mine from the column shifter. Thank You. I will PM you my phone number. Thanks again
Old Feb 8, 2009 | 09:14 AM
Bluevista's Avatar
Registered
How about nothing
Free
Oy gevalt!... such a deal.
Can you post pics of the rat and the wires if it ate it? Any scuffs?
I'm sure that column will work up to '72, my knowledge base drops off after the last good year for American cars.
I think it'll fit in a '68 too, if you can figure out where to stick the ignition key more power to you.
Old Feb 8, 2009 | 09:17 AM
Yeah 69 first year key in column
Longhorncutlass
Dec 3, 2014 04:25 PM
WTony
Jul 7, 2014 05:37 AM
zk194
Oct 11, 2013 11:10 PM
dc2x4drvr
Oct 19, 2009 04:20 PM
LIMEGREEN71
Sep 19, 2009 01:09 PM
