69 cutlass
69 cutlass
i would like to know what i have i found a 69 cutlass supreme with a 455 rocket in it sent from factory stock not sure if it was special order or what
this car is canadian made
is there anyone thast can help me find more info or knows more about these cars
thankyou for the help
Hello jimlinnell.
First of all are you sure it is a supreme? If it is the serial no should start with 6934287os. 69 is year.3 is oldsmobile. 42 is cutlass supreme. 87 is holiday coupe. os is the plant it came from, Oshawa. I own one but mine has 350 rocket. on the 350 there is a production no stamped on the front driver side of the block. You will need a mirror to see this or maybe from underneath. from what I understand, this no should match the production no of the car. I am not sure if 455 is the same. There is lots of info on the net. That is where I got all mine and I aint no Genius. Where are you from? Im from prince Edward Island Canada. Let me know more about this car , you dont see too many 69 supremes around . In fact mine is the only one I ever saw.
GOOD LUCK!
GOOD LUCK!
