Window Fuzzies
Window Fuzzies
Hi, I have purchased new door panels (Legendary Interiors) for my 67 Cutlass Supreme. I am also replacing the door fuzzies. I noticed the fuzzy on the outer door skin has a small chrome strip. I received new fuzzies with the car when I purchased it. However, these fuzzies don't have the chrome strip. The problem is the car has been repainted and the small chrome strip was taped off. If I remove the outer fuzzie with the chrome strip and replace it with the new fuzzy there is a distinct line of old paint that doesn't look good. Is there a special set of fuzzies for the 67 Cutlass Supreme? I suppose I could glue and screw the new fuzzy to the old strip. Any help would be appreciated. Thanks...Carl
The small bead is simply crimped over the rubber. The aftermarket sells three types of outer fuzzies. The "bare" fuzzies (no chrome at all), the flat chrome bead, and the correct round chrome bead. The latter are the most expensive because they are the only factory correct repros. Personally, I'd just get the correct parts.
Wow...I am having trouble here. I ordered new window fuzzies from OPGI with the bead. I received the fuzzies only to find out they were 28 1/4" long. Mine are 31 1/2" long. I return the ones I had and received another set a bit different. They had the correct clips for the exterior of the door, but. again 28 1/4" long. I believe I have a Holiday coupe, but am not sure. I say it' a Holiday Coupe, because it has the C/S interior door emblems. I am sure of the length at 31 1/2". Can anyone tell me which model fuzzies I need. OPGI is going to send me another set for a 442.
OK..thanks Joe. Is there somewhere I can find out the length of the front door, outside, fuzzy for my car (31 1/2")? I understand my car it be a holiday coupe, (no pillar) Should the holiday coupe have the s/c emblems on the inside front door panel? I haven't put them back on yet, as I am waiting for the fuzzy resolution. I may not put them on if they don't belong. Just getting frustrated trying to get the right size fuzzy.
mbrae5
Jan 14, 2013 02:30 PM
