Care and Appearance Washing, waxing, paint care products, etc.
Restoring chrome!
Old Oct 22, 2015 | 09:28 AM
Copper Nine Eight's Avatar
Restoring chrome!
What can I use to get my big chrome bumpers back like new?! And the trim around the windows and stuff. Just bored and wanna do little touch ups on my 85 Delta88.. Thanks!
Old Oct 22, 2015 | 09:42 AM
Tedd Thompson's Avatar
Try WD40 and 4/0 steel wool. The WD40 helps remove oxidation and crud , the steel wool will knock off small rust bumps. Then wax with a paste wax..... Tedd
Old Oct 22, 2015 | 10:01 AM
I use fine steel wool with dish soap and water, then wax.
Old Oct 22, 2015 | 10:32 AM
Any wax recommendation?
Old Oct 22, 2015 | 10:33 AM
What wax would you recommend?
Old Oct 22, 2015 | 12:33 PM
Any Carnauba auto wax.
Old Oct 22, 2015 | 03:27 PM
I use Mothers Paste Wax just because I have it, works for me....Tedd
Old Oct 22, 2015 | 04:47 PM
ignachuck's Avatar
Frank Ignachuck
X2 for Mother's
Old Oct 23, 2015 | 09:35 AM
Don R.'s Avatar
Be careful, by 1985 a lot of the "chrome" trim was not plated steel or diecast. Depending on the model and application some of the trim was polished or anodized aluminum or plated plastic, you do NOT want to use any type of steel wool or abrasive cleaner on these materials. You are probably OK with the bumpers but check with a magnet first. I learned this the hard way on a 77 Olds 98!
Old Oct 23, 2015 | 09:52 AM
Octania's Avatar
They say coca cola and AL foil ball works wonders
try an inconspicuous spot first.
Old Apr 23, 2016 | 06:01 AM
zeeke's Avatar
I use a product called AutoSol, metal polish. If the bumpers are not to pitted it usually pulls the rust right out with just a rag. I've tried buffer wheels with this product but had better results with a rag. Leaves a nice coat that lasts. Draw back is you can only get it on line, but it keeps the cost down. Watched a demo at a Carlisle, PA car show about 25+ years ago and for a few bucks I took a shot. Surprisingly enough it wasn't snake oil. I've been using it ever since. Their Stainless Steel polish works great too, especially on kitchen appliances. I just tried their aluminum polish but I think I get better results out of the metal polish.
Old Apr 23, 2016 | 08:48 AM
RROLDSX's Avatar
X2 for the Autosol. I also use an electric cutoff tool (HF) with a small thin buffing wheel and jeweller's rouge buffing compound. If you polish it on the car make sure you mask along side cause you are gauranteed to ruin you paint if you slip off.
Old Apr 23, 2016 | 09:20 AM
442fanatic's Avatar
For the trim pieces - Iverson Automotive out of Minnesota. Took all the dents out of my wheel well mouldings and polished them to a mirror.
You will have to check if they do bumpers
Old Jul 14, 2016 | 04:59 PM
ignachuck's Avatar
Frank Ignachuck
This thread goes back a while, but I bought a tube of Autosol based on the comments here, and just got a chance to try it this afternoon.
This stuff is very good.
Old Jul 14, 2016 | 05:25 PM
Rocketowner's Avatar
I bought a tube called "Semi Chrome metal polish" (from a Honda motorcycle dealer) that worked well on most any kind of metal. Larry
Old Jul 14, 2016 | 05:32 PM
76olds's Avatar
Hookers under Hood
Thanks for bumping this older thread with a good review that added to others Frank,
I use mothers on my chrome bumpers but just doesn't seem to last. The little scratches are visible in not time.
I will order some Autosol and give it a try.
Cheers
Eric
Old Jul 14, 2016 | 06:08 PM
Cutlass71s's Avatar
I've Been using this for over 20 years and have found nothing better.
Sgt17
Jan 26, 2014 07:53 AM
obsessedw/musclecars
Jun 27, 2007 08:05 PM
mr-tom
Feb 25, 2007 05:39 AM
69cutlassgirl
Apr 25, 2006 04:44 PM
Mar 27, 2006 07:01 AM
