need wheels
need wheels
I have a 1968 Delta 88 with the stock steel wheels/hubcaps.
I am looking at this front disc set up that will require I get larger rims, the kit says I can use '71- GM steel wheels...and luckily I have a '76 cutlass sitting around, with post-'71 steel rims on it.
however, my hubcaps won't fit on the later wheels, and I'm sure the wheels were larger for a reason, so I can't put the '68 wheels on the cutlass.
does anyone know if I can buy steel wheels that will accept the smaller hub caps?
also budget-in-mind, I'll take suggestions for alloys that would look kickass on my car. I don't want to put 20s or anything massive on it, and a little more grip in the rear would help. I'm going for a classy looking daily driver here, not a race car or a show car.
"This setup eliminates the stock ball bearings with safer, cheaper tapered roller bearings yet still preserves the stock 5 on 5 inch bolt pattern. "
WTH is that about?
What "ball bearings"?
weird that they skipped 1965 Big Cars in the list of applications. What's different about the '65 Olds Big Cars ??
WTH is that about?
Originally Posted by copy/pasted from the ad
1965 models require rework of the stock drum hub due to use of smaller bearings.
I have doubts that your '76 Cutlass wheels will fit your '68 Delta 88. The bolt pattern on your '68 should be 5 x 5". The bolt pattern on the Cutlass should be, 5 x 4.75".
When I switched from 14 x 6 wheels to 15 x 7 wheels on my '67 Delta, I used 15 x 7 Chebby truck rims from the '80's. My wheel covers from '67 would no longer fit, so I ended up purchasing wheel covers from a '73 Olds with 15" rims.
The reason I switched from 14" wheels to 15" wheels was because I couldn't obtain the proper size 14" radial tires. I believe the proper tires are non-existent.
My '67 Delta originally had manual drum brakes. Adding a power brake booster greatly increased my stopping power. I would suspect that your car already has power (drum) brakes, but I know, you most likely want to be able to stop even sooner. Stopping when we want to is a very good thing. Good Luck!
I had an idea a couple of days ago. I was looking at a 69 Impala that had factory disc brakes and a 12 bolt rear. I believe that 65-70 big cars share the same frame so why couldn't the Impala setup be installed on an Olds? It would give disc brakes, a 12 bolt Chevy rear that is easy to find parts for, and a 5x4.75 bolt pattern which would allow installation of any of the many wheels available for the Cutlass/442 A-body platform
Joe, I was thinking about a complete exchange of all front suspension, everything that attaches to the frame, upper and lower a arms, sway bar, and all attached hardware and parts. That is why I was saying I believe the frames are the same because, if they are, this exchange would work for the front suspension and the rear exchange as well.
