Metallisation
Old Oct 5, 2016 | 01:25 PM
Metallisation
Stumbled across this on another forum, looks interesting. Had not looked into the cost of equipment yet.
Old Oct 5, 2016 | 01:35 PM
tru-blue 442's Avatar
Old School Olds
Pretty cool. Looks like they stay back far enough to keep from warping the material.
Just think how many trunk lids might be saved. Interesting to say the least.
Thanks for the post.
Old Oct 5, 2016 | 01:41 PM
It looks pretty easy, there is also a system for aluminum and other materials. Have not found a cost for equipment yet.
Old Oct 5, 2016 | 02:08 PM
It's gotta be lead, or some similar soft metal.
And that was filmed in the UK or A-NZ, so it may be unavailable here.
Old Oct 5, 2016 | 02:28 PM
We are a world wide economy, don't you pay attn?
Old Oct 5, 2016 | 03:26 PM
Yes, but there's not a world wide EPA.
Yet.
Old Oct 5, 2016 | 03:48 PM
There is a distributor in Washington state.
Old Oct 5, 2016 | 04:39 PM
oldolds88's Avatar
when I worked for gm the hot sprayed silicone bronze on the roof to quarter seams in place of the lead
Old Oct 5, 2016 | 06:07 PM
I think that only applies to employment (or loss thereof...).
Old Oct 5, 2016 | 06:39 PM
TripDeuces's Avatar
Body shop friend said the silicone bronze mig stuff is the thing. Haven't tried it yet.
Old Oct 5, 2016 | 07:40 PM
coppercutlass's Avatar
Chevy budget Olds powered
silicone bronze is amazing. We outfitted a welder at work to used that wire which just requires straight argon gas vs a mix. But welding seams when replacing quarter panels is a breeze specially when you butt weld stuff like quarter panels and patches etc etc . No warp and you can pretty much just lightly grind the weld and file it down.
We just got a pro spot welder so we can now weld on quater panels just like the factory does with resistance welding.
i also agree this has to be a soft metal alloy.
Old Oct 5, 2016 | 07:58 PM
70Post's Avatar
it's probably zinc (or a mix) and it's been around in the US for many, many years already. There was/is a place that used to advertise in Hemmings or some other car related venues and they called it "spray welding" or something similar. They were trying to sell franchises.
Old Oct 5, 2016 | 08:54 PM
steverw's Avatar
Wonder if it would work on pop metal?
Old Oct 5, 2016 | 09:29 PM
70Post's Avatar
There's another method used by some to repair pot metal....a product called "Muggy Weld". Another mix of softer metals but with a much lower melting point than pot metal itself. It's a stick form and you use a torch to melt and apply it. I have no idea how well it works or holds up but it's also been around for many years.
Old Oct 6, 2016 | 07:47 AM
This is called flame spraying and the technique has been around for decades. It is primarily used to build up worn areas on industrial equipment. The concept uses either an oxycetalene flame or an arc to melt the filler metal (which can be almost anything) and compressed air to spray it onto the part to be repaired. The filler can be either powdered metal or a wire feeder like a MIG. If strength of the repair is important, the part must be properly heated. There are a number of companies who do rust repair on sheet metal this way.
Old Oct 6, 2016 | 04:26 PM
76olds's Avatar
Hookers under Hood
I'm surprised this has been around for decades, You would think many more cars could have been saved over the years. Especially up here in Canada. I've never heard of the method posted.
Interesting.
Eric
Old Oct 6, 2016 | 04:55 PM
TripDeuces's Avatar
One site I went to said they started in 1922. That's awhile
Old Oct 6, 2016 | 05:15 PM
http://nickorso.com/rust-busters/
http://www.rustbustersllc.com/www.ru...ustersLLC.html
Old Oct 18, 2016 | 05:52 AM
wr1970's Avatar
I seen one of those machines. I didn't see it in operation.
