Floor pan
Old Jul 25, 2020 | 10:32 PM
big man's Avatar
Floor pan
Got a 71 Cutlass convertible and just finished up doing the trans and would like to replace the floor pan.
I do have welding experience and am mechanically inclined, but I don't have body work experience..
It's been horribly 'repaired' and I've got a few questions before I take the plunge. In opgi its got the whole pan and I was wondering if it would be easier to cut it up in sections and replace it bit by bit? Reason being is because I'm not sure if things have got to be braced and I certainly don't want it screwed up. Is this a complicated process? Will this require more people? Other than seats what else needs to be removed?
If someone can give me a run down of what to expect that would be great, thanks in advance..
Old Jul 26, 2020 | 05:53 AM
I have always thought it better to keep as much as possible of the original floor. I've even bought full panels and used maybe only 1/4 of it. If you leave as much as possible then you know at least that part is correct.
Old Jul 26, 2020 | 06:39 AM
RandyS's Avatar
IMO, If you only have to replace rusted out sections you can use replacement panels. If it turns out you need to replace the entire floor, go with the full floor. It is a REAL PITA to use 1/2's or 1/4's, The seams don't always match up, and there is way too much welding and grinding.
Old Jul 26, 2020 | 09:31 AM
big man's Avatar
Cool. Looks like it could go either way. I'll just have to pull the seats and carpet and see which is the better replacement. Thanks
Old Jul 26, 2020 | 12:45 PM
2blu442's Avatar
Where are you located? I've got some floorpan sections available for patches and am sure other members here do too. If one of us is close to you that might be an option to consider.
Old Jul 26, 2020 | 02:29 PM
PatL's Avatar
Wait until you receive the new floor pan (or sections), before you cut anything out...…….
Old Jul 26, 2020 | 03:08 PM
big man's Avatar
Lexington Ky.
Noted, thanks.
Mossy
Body work
17
Apr 2, 2020 04:35 AM
NotDads442
Body work
Apr 1, 2018 11:28 AM
stevengerard
Body work
Feb 16, 2017 07:52 AM
Bfg
Jul 18, 2014 08:11 PM
AirborneRME
Body work
Jun 11, 2013 07:34 PM
