Core support
Old Dec 13, 2022 | 09:46 PM
chasmo's Avatar
Core support
I'm sure my core support is out of square on my 70 442. I'm having trouble gapping my hood. Factory W30 hood. I'm fairly happy with the fender to doors gaps. I ran a string down the side of the car to check side to side. Got that squared, but just seems to be a twist in front. I measured off the firewall to hood pins got equal distance. Any suggestion's.
Old Dec 15, 2022 | 07:18 PM
Eddie Hansen's Avatar
Core support shims?
Are you using core support shims? If not this might be the issue
Old Dec 15, 2022 | 07:22 PM
They look like this available from the parts place
1970 Oldsmobile Cutlass/442/F85 CORE SUPPORT BUSHING SPACER SHIM 1/8'' THICK RECTANGULAR W/ TAB & SLOT (USED TO SHIFT UP CORE SUPPORT TO IMPROVE BODY LINES) - SET OF 4 Price: $12.95
Old Dec 15, 2022 | 08:03 PM
chasmo's Avatar
Thank you, Ed. I will see what I can do by shimming. Merry Christmas
Old Dec 16, 2022 | 07:08 AM
merry Christmas!!
Old Dec 17, 2022 | 01:15 PM
Post70's Avatar
Can you make an x measurements from the center of the rear fender bolt on the top of the firewall to the center of the front fender to core support bolt? If they aren’t the same measurement loosen the core support bolts and move the front clip over until they are. If they are the same move the hood on one side forward or backwards until the fender to hood gaps line up. Have any pics?
Dustin
Old Dec 19, 2022 | 08:20 PM
chasmo's Avatar
Thank you, Dustin. I'm gonna loosen things up and see where I'm at. I'll touch base with you.
Thanks again,
Chasmo
twiceflooded
Feb 4, 2022 01:49 PM
Rusty Boltz
Apr 1, 2020 08:28 AM
NotDads442
Apr 8, 2019 12:23 PM
JuzCallMeDee
Body work
Jul 5, 2013 02:53 PM
Resistanc3
Oct 23, 2011 09:20 AM
