Wrong Camshaft
Old Feb 14, 2026 | 11:41 AM
DanM's Avatar
Awesome User
Wrong Camshaft
I bought a camshaft from FCRPerformance.com 20 years ago. Engine ran briefly but had issues (was young and didnt know what I was doing). Rebuilding properly now.
While looking to reassemble and reading up on thrust faces for the camshaft... mine has none. Is this the wrong cam? Why wouldn't it has a thrust face surface if for an Olds V8? I also attached the cam card, the part number matches the stamp on the other end.
Old Feb 14, 2026 | 11:59 AM
oddball's Avatar
Looks like there's supposed to be a spacer/disk on the nose. It would look like a really big, really thick washer with one hole for the bolt hole and one hole for the alignment dowel. It'd be retained by the timing gear and larger than the cam journal so it would act as the thrust surface.
Don't run it without that spacer.
Old Feb 14, 2026 | 12:03 PM
DanM's Avatar
Awesome User
I figured as much, but can't find it around and don't remember if I saw it when I pulled it apart. Uggh
Old Feb 14, 2026 | 05:21 PM
DanM's Avatar
Awesome User
Has anyone ever seen a spacer/washer like this for sale anywhere? I can't find anything
Old Feb 15, 2026 | 07:31 AM
67OAI's Avatar
Old(s)GuysRule
Have you contacted Lunati?
Old Feb 15, 2026 | 08:00 AM
DanM's Avatar
Awesome User
not yet, will do so monday
Old Feb 15, 2026 | 09:27 AM
Duh's Avatar
Duh
This post has a picture of what you are missing.
https://classicoldsmobile.com/forums...-plate-111950/
Old Feb 15, 2026 | 09:33 AM
BillK's Avatar
Interesting. I don't do a mess of Olds engines but I don't think I have ever seen an Olds cam without the thrust area. You might have to do some measuring and have somebody make you a spacer to go in there between the front of the cam and the timing sprocket. It will need to be the correct thickness to position the cam properly.
Looks like a roller cam too so it will need something to keep it from moving forward.
I have a pretty old Lunati catalog at the shop. Ill take a look in the morning and see if it mentions anything.
Old Feb 16, 2026 | 04:04 AM
BillK's Avatar
I just looked in a 2006 Lunati catalog and there is no mention of any type of spacer.
Old Feb 16, 2026 | 06:33 AM
DanM's Avatar
Awesome User
Andy at OldsPerformanceProducts mentions that those were for diesel engines. I also came across someone selling a similar cam on ebay listing it for an Olds 307 / 350. Looks like I need to buy a new cam.
Old Feb 16, 2026 | 08:18 AM
BillK's Avatar
Not sure what the front of the cams look like for the oem Hydraulic roller engines. 85 and newer ? As long as everything else is fine it should be a fairly simple job for someone at a precision type machine shop to make you a spacer for the front. I would still call Lunati and see what they say.
Old Feb 16, 2026 | 08:23 AM
BillK's Avatar
I just looked at some pics of the Melling SOC14 which is for the factory hydraulic rollers and thats what it look like. You could probably use it IF you can find one of the factory thrust plates like DUH linked to and use the correct timing set. The thrust plates are very difficult to find.
Old Feb 16, 2026 | 10:27 AM
Duh's Avatar
Duh
I think this is how roller hydrologic cams were done be fore a dedicated roller core for retrofits. I'll look when I get home but the old Mondello tech guide said something about it.
Old Feb 16, 2026 | 05:25 PM
Duh's Avatar
Duh
I looked. Just had a part number for the camshaft gear adapter. GS 125.
Old Feb 17, 2026 | 06:19 AM
DanM's Avatar
Awesome User
Luckily I finally found one for sale: https://rocketracingperformance.com/...mshaft-adapter
Old Feb 17, 2026 | 06:21 AM
BillK's Avatar
Wow ! There you go
Old Feb 17, 2026 | 06:23 AM
BillK's Avatar
If you dont already have one you need to get a cam button too. I think OldsMotion is making a bronze one.
Old Feb 18, 2026 | 05:39 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Dick Miller has them as well, so does olds performance.
Old Feb 18, 2026 | 06:02 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I would bet Rocket Racing also has a button as well. I got my button from Cutlassefi.
Old Feb 18, 2026 | 08:39 AM
DanM's Avatar
Awesome User
ugh they dont have them in stock anymore, back to the search
Old Feb 18, 2026 | 08:47 AM
skyhigh's Avatar
RR is backorder but did you try others such as Andy miller at olds performance or Dick miller? or Mark cutlassefi? Im sure one of these fellas will hook you up.
Old Feb 18, 2026 | 08:52 AM
DanM's Avatar
Awesome User
I need the camshaft spacer, not the thrust button. Already have that
Old Feb 18, 2026 | 09:56 AM
CANADIANOLDS's Avatar
first off, what engine/year block is it going in?
that’s a factory hyd roller . they don’t come with any of the front hardware..you reuse your old stuff.
they can also be used in non roller blocks while using only the cam thrust peace which is pinched between the cam gear and cam. plus a regular thrust button
im sure someone on here will have that piece you need. They came on all 307 and Diesel rollers
Old Feb 18, 2026 | 10:26 AM
DanM's Avatar
Awesome User
its a 69/70 455 'F' block. my engine didnt have the thrust piece with the original cam. I'd love to buy it from someone if they have it!
Old Feb 18, 2026 | 10:56 AM
BillK's Avatar
Dan,
The factory engines never had that piece unless it was a roller from the factory which was 1985 and newer 307's and the diesels.
Old Feb 18, 2026 | 02:01 PM
yours wouldn’t have had it. put a wanted add in the classifieds on here.
Anderson
Feb 28, 2022 12:14 PM
h/o guy
Jan 19, 2021 04:00 PM
edzolz
Aug 27, 2017 04:26 AM
oldman8187
Jan 8, 2017 02:33 PM
DennisG.
Jun 14, 2008 12:18 PM
