Timing cover question
Old Aug 21, 2016 | 04:33 PM
CJG's Avatar
CJG
How important is it for the cover to be smooth and paint free where the water pump gasket mounts? It has been painted and there is some rough/ridged/pitting behind the impeller area and where the gasket goes. Will smearing a thin film of rtv and the gasket seal the water pump ok? Don't want to have to do it again in the car.also we are going to remove the inner valve springs per comp cams recommendation for break in but there is also a flat metal spring-like thing in there besides the 2 springs. Does not need to come out as well?
Old Aug 21, 2016 | 04:47 PM
I like the gasket surfaces to be clean and oil free. The metal things you are talking about are rotators. You can leave them in for the break in.
Old Aug 21, 2016 | 04:50 PM
CJG's Avatar
CJG
Ok we can get the paint off pretty easily but how do you know if the rough/pittedness, for lack of a better term,is too much to seal properly?
Old Aug 21, 2016 | 05:12 PM
You can put a thin coat of sealer on the cover surface.
Old Aug 21, 2016 | 08:18 PM
My2nd 69 442's Avatar
Use a good quality sealant not the standard hardware store stuff
Old Aug 22, 2016 | 07:09 AM
Actually, the flat spring is a damper designed to damp out vibrations in the valve spring itself. Valve rotators are the thick retainers on top of the springs used on some Olds motors.
This is a valve rotator.
This is a damper (inside the spring).
jpc647
Jun 10, 2013 11:48 AM
Hairy Olds
Oct 27, 2011 05:35 AM
442scotty
May 13, 2009 05:42 PM
sklbndt
Apr 15, 2009 04:34 PM
csouth
Jan 21, 2009 09:35 AM
