pulley
Old Nov 30, 2011 | 11:02 AM
D Appeldorn's Avatar
pulley
need some help,
we talked about the pulley's a time ago.
i do have a more or less maching AC pulley's on my b body 69 88.
and do not have the ac on it.
I damage the pulley off the steering pump trying to get it off while rebuilding it.
problem off the pump is fixed, but not the pulley of it.
So i need a new pulley on my steeringpump.
But if anyone having a set of pulley's lying around to mount on a b body without AC is more than welkom.
And if someone know what kind i need if i want to buy new ones pleace tel me with one.
Old Nov 30, 2011 | 03:32 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Let us know the letter stamping on your old power steering pulley. Usually those had kf water, kc crank, and the steering.....
I'm guessing it will be KH.
If you have something different, post up your letter stampings.
Old Nov 30, 2011 | 11:51 PM
gonna try and sandblast mij waterpump and crank pulley.
and gonna search the number of the steering pulley.
Old Dec 1, 2011 | 08:58 AM
i did nake some pictures today off the pulleys.
Uploaded with ImageShack.us
This is the crankshaft pulley a 3 row (3)99405 KC ?
second and third pic is the waterpump pulley.
only stamp i could vind is B9 s and LD
the last pic is from the steeringpump,
i think it is a total mismatch off the pulleys, former owners did some stuff him self regardles if it was original or not.
i hope that one of you guys can help me with they pulleys, the steeringpulley is bent.
and i do not have AC. and do not need the 3 row.
Old Dec 4, 2011 | 07:34 AM
is this waterpump pulley an olds pulley?
becouse off the strange cast numbers?
And what numbers can i use to loose that 3 row pulley's becouse i do not have a ac mounted.
Old Dec 4, 2011 | 07:59 AM
The LD pulley is most likely from a 77-80 350 or 403 motor.
It's the same thing as the KE 3 groove pulleys on all the earlier 70's cars.
I'm not sure why LD stamp was even used.
Anyway, 2 of your pulleys are the original.
I would just find another KH steering, and run the pulleys you have if they work.
I still run ac pulleys on the cars that I drag race. No problems.
If you switch to the NON ac pulley setup, you will have to mount the alternator on the passenger side, and change your water pump length.
Old Dec 4, 2011 | 11:14 PM
ok thanks,
gonna post a request on vinding a kh pulley.
Oldsfan
Apr 23, 2007 09:22 AM
mcutlass1969
Mar 26, 2007 07:09 AM
drpruitt
Sep 25, 2006 06:46 AM
DonFrost
Jun 25, 2006 03:14 PM
<Rocket Power>
Dec 8, 2004 05:44 AM
