piston question
Old Feb 29, 2012 | 09:14 PM
72hurst's Avatar
piston question
I bought a rebuilt 455. It is supposed to be a stock rebuild. I opened it up to see what I really had and saw that the main and rod bearings were standard, so I took off a head and found big valves and low compression pistons. The thing I don't know is what bore or overbore the pistons are at. I thought I would see 030 or 040 or something similar on the pistons but all I see is the letter C on three pistons and a B on the fourth. The pistons have a really deep dish. That is why I said they were lo-comp pistons. If anybody can help with those letter markings I would really appreciate it. Thanks in advance.
Old Mar 1, 2012 | 03:35 AM
Those are factory tolerance band stamps. They should correspond to identical characters stamped into the head gasket surface of the block adjacent (more or less) to each cylinder bore. I was not aware that aftermarket pistons carried these markings, so, unless someone here knows better than I, I would suggest that these sound like the original pistons (and therefore bore). Pictures would help.
This chart is from 1972 - I am not certain whether the details are the same for all years or not (would have to review each CSM...).
boese1978
Mar 6, 2013 12:37 PM
sicky olds
Jun 20, 2012 06:19 PM
72hurst
Jan 9, 2012 08:27 PM
dave1978
Dec 6, 2010 12:14 PM
Deputy442
Apr 19, 2009 04:06 AM
