Help! needed for ignition settings
Hi! from Germany!
I have a small
problem with settings of my engine...
who does it know ...something about signs on the plate on the picture ? what is it this small slots in the plate, holes and square-hole ? where can i find the Information about it ?
how is the correct setting of a ignition or your recommendation for 1966 Toronado?
Thanks for the help!!!!
Greeting
I have a small
problem with settings of my engine...who does it know ...something about signs on the plate on the picture ? what is it this small slots in the plate, holes and square-hole ? where can i find the Information about it ?
Greeting
Carburetor
Hallo again 😉
It would like to rebuild and to make a new setting for my old carburetor 1966 Toronado
Part number is 7026250 ..... also veeery old
Do you have any idea or address in US where I could do it ? Or have got somebody an experience with this job?
Greeting from Germany
Carburetor quadrajet
Kent in Sweden is a really the best one. I talked with him about the problem. After sending my carburetor everything was perfect rebuild with new setting in only 4 days. Really professional job with a lot of knowledge. A big report I get too. Not only a new gasket.....calibration new part etc. .....
So now I'm waiting for it. At home I would like to make finals setting on running engine - if necessary
Than I give you report about new work and performance
Thank for the help
Wojtek
Thank for the help
Wojtek
