Harmonic Balancer...HELP
Old Apr 9, 2013 | 08:16 PM
squirell's Avatar
Govt slave
My Harmonic bal on the 455 is wobbling.
From all I have seen in the catologs they are the same application for
260-455 .... others list 350-455
However the one on my 330 is about 3/4" wide and the one on the 455 is about 1-1/4".
I don't know what the difference is between the 2
(besides the thickness )
Old Apr 10, 2013 | 07:46 AM
What those catalogs MEAN to say but don't is that the application is 1968-up, not just 260-455.
Old Apr 10, 2013 | 09:59 AM
Run to Rund's Avatar
The differences include counterbalance, position of the timing mark, diameter, thickness.
Old Apr 10, 2013 | 08:49 PM
squirell's Avatar
Govt slave
So..I can use the one from my 330 on the 455 ?
Old Apr 10, 2013 | 09:04 PM
copper128's Avatar
Lt. Buzzkill (ret.)
No. It would probably physically fit, but it is not correct for the 68-up engines like the 455.
The way balancers are divided for Olds engines:
'64 330 only
'65-67 all (330, 400E, 425)
'68-up all (350, 400G, 455, 403, 260, 307)
Old Apr 11, 2013 | 11:39 AM
squirell's Avatar
Govt slave
'64 330 only
OK...I need one...prices range from $55 to $455.
What is the difference between a Damper and a balancer ?
Any recomendations ?
I was looking at this cheap one (balancer) :
Dorman Products 594-117
http://www.jegs.com/i/Dorman+Product...4-117/10002/-1
Old Apr 11, 2013 | 11:44 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Which one depends on the intended usage.
Assuming this is a street car and won't be raced or see high RPM often, the Dorman one you posted will work fine. A reman factory one is probably even better.
For a high performance application, I'd want to use something better.
Old Apr 11, 2013 | 11:57 AM
squirell's Avatar
Govt slave
Gonna be a street car thats get beat on now and then.
Where can I get a reman one ?
more options:
http://www.summitracing.com/search/department/engines-components/section/harmonic-balancers/make/oldsmobile/engine-size/7-5l-455
Old Apr 11, 2013 | 12:14 PM
copper128's Avatar
Lt. Buzzkill (ret.)
http://www.damperdoctor.com/Merchant...egory_Code=OLD
Old Apr 12, 2013 | 06:30 AM
squirell's Avatar
Govt slave
Awesome....thanx
Old Apr 12, 2013 | 07:01 PM
BILL DEMMER's Avatar
Just the facts...
i have nos gm 417142 balancers available, see parts for sale.
bill
rroth01
Dec 3, 2016 06:27 AM
Gert3116
Apr 23, 2008 08:53 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
