Difference in auto & MT intake?
Old Jan 3, 2009 | 05:22 AM
scrappie's Avatar
Planning on converting my 71 442 conv. to a 4spd. down the road. I have been gathering all parts before hand. Is there a difference between intake manifolds for auto and MT cars?
Old Jan 3, 2009 | 05:30 AM
In 1971, yes there is. The MT cars used an intake with the PCV valve in the manifold behind the coolant crossover. This is the same location as the W-30 intakes, but the MT intake was cast iron, not aluminum. Casting number 407567, code letter R. These are pretty rare. Unless you care about complete correctness, you can use your current intake.
Old Jan 3, 2009 | 06:00 AM
scrappie's Avatar
Thanks Joe, So if I were to find the correct intake what would I do with the PCV valve inlet in the valve cover?
Old Jan 3, 2009 | 06:04 AM
scrappie's Avatar
Now that I think about it That is probably were the PCV valve hose connects instead of carb? right?
Old Jan 3, 2009 | 07:09 AM
The MT cars had two breathers, both going to the air cleaner.
Old Jan 3, 2009 | 10:32 AM
scrappie's Avatar
I understand the difference now. Why did Olds design it two different ways? Was it a vacuum thing or performance?
ignachuck
Jun 12, 2015 05:29 PM
svnt442
Jul 17, 2011 04:43 PM
BIGJERR
Jun 1, 2010 08:05 AM
ctrain22
Apr 26, 2009 08:19 AM
68Tom
Apr 9, 2009 07:11 AM
