deck height question
Old Jan 31, 2015 | 12:26 PM
sbceater's Avatar
Is it possible to deck a 455 to 10.6?
I'm asking cause I'm using a set of pistons with 1.720 pin height and I'd like to keep quench around .050 and also have 10:1 compression
Old Jan 31, 2015 | 12:40 PM
rootney's Avatar
You need to check the volume (CCs) of your heads.
Assume you are going to ask the machine shop for "zero" deck gap with the pistons and rods you have. Select a head gasket to get your .050" quench. Then do the math or use a comp ratio calculator and include any "dish" volume of the pistons (you didn't say what pistons they were).
If the comp ratio is lower than desired, go to flat top pistons, perhaps a .038 - .040" head gasket and finally mill the heads. Discuss your findings with the shop and let them advise.
Good luck
George
Old Jan 31, 2015 | 02:51 PM
sbceater's Avatar
I cced my heads they are 85 cc at the moment, I will have them milled to 80cc the Pistons are 13.2cc the head gaskets I'm using are .028 thick and the pin height of the Pistons is 1.72.
if I can deck the block to 10.6 it would put them .020 in the hole, I'm asking if it's safe to take a 455 to 10.6 deck height
Old Jan 31, 2015 | 06:05 PM
cutlassefi's Avatar
Yes 10.600 is fine. You'll have no issues.
Old Jan 31, 2015 | 06:16 PM
sbceater's Avatar
Thank you for the replies, cutlassefi
do you grind custom cams?
Old Feb 1, 2015 | 07:28 AM
cutlassefi's Avatar
Yes I offer custom flat tappets and rollers. Let me know, thanks!
Oldskool84
Feb 12, 2014 09:49 PM
highschoololds
Suspension & Handling
Feb 11, 2012 12:46 PM
oldzy
Aug 7, 2011 12:38 AM
RAMBOW
Dec 29, 2010 01:06 PM
geckonz08
Aug 11, 2008 11:11 AM
