D head casting dates &c.
Old Feb 23, 2014 | 12:55 PM
Octania's Avatar
Database does not claim to be complete but it says the few casting dates ever made for D heads are:
3, 41, 136 ?, and 265
So, is there any way to use this info and a calendar perhaps to ascertain more info?
Let's say for example you find that "3" was a sunday in 1968.
1/3/67 would be too early to be making '68 heads, and 1/3/68 is ruled out assuming they did not work weekends. That leaves 1/3/69 [assuming that is not also a weekend].
Can anyone
-provide all known D head casting dates
-contribute to what is known about deciphering the YEAR of the casting, or, more particularly, which range of vehicle assembly dates would be expected for each of the known head casting dates?
I have a guy refurbishing the 1968 H/O and he wants to be sure that the heads it has are what it should have.
For my car, I was all happy to get ANY "D" heads at all, and casting date was not really a concern. Especially considering all the other replaced parts that are no longer as it was manufactured.
Old Feb 23, 2014 | 01:05 PM
72xw30's Avatar
My 68W30, built APR. 30/68 has D heads that have a julian date of 41.
My 69W30, built DEC. 10/68 has D heads that have a julian date of 265.
Cheers,
Sam
Old Feb 23, 2014 | 01:38 PM
Octania's Avatar
Thanks, Sam
So far I have deciphered:
Julian Day 1967 1968 1969
__3 Tu 1/3/67 Wed 1/03/68 Fri 1/3/69
_41 Fri 2/10/67 Sat 2/10/68 Mo 2/10/69
136 Tu 5/16/67 Wed 5/15/68 Fri 5/16/69
265 Fri 9/22/67 Sat 9/21/68 Mo 9/22/69
1968 being a leap year, the dates after 2/28 are one less for a given Julian number than they would be for a non-leap year.
Thinking we can rule out 1/3/67 and 2/10/67 as too early for '68 production.
Similarly, we can probably rule out 9/22/69 as too late for '69 production parts. They'd be making E's and F's by then.
41 4/30/1968 Sat 2/10/68 would be about 80 days before final assembly
265 12/10/1968 Sat 9/21/68 would be about 80 days before final assembly.
Assuming these are heads original to the car [I am never that lucky], this indicates that Saturday castings were made, for the most likely available dates were both Saturday.
Old Feb 23, 2014 | 04:27 PM
66trakpak's Avatar
I have a set of 171 date D heads
Old Feb 23, 2014 | 05:41 PM
Octania's Avatar
day 171 might be
Tu 6/20/67 or
Wed 6/19/68 or
Fri 6/20/69
going over photos now
I found a D head photo showing day 194 also.
Old Feb 23, 2014 | 10:11 PM
hurst68olds's Avatar
I used to own a '68 W-30 "11B" build week.
I have 2 pics of the heads but can't make out the date? Which number is the date?
Old Feb 23, 2014 | 10:24 PM
I also had a pair of "110" but they came off a '73 455 in a boat.
110 = Friday, 4/19/68 "leap year"
110 = Sunday, 4/20/69
Old Feb 24, 2014 | 09:42 AM
Octania's Avatar
OK, add 110 to the mix after work
Interesting way to run valves there
must be an old mariner's trick
Old Mar 2, 2014 | 10:20 AM
Octania's Avatar
So far we have
Julian
Day____1967______1968________1969
__3__Tu 1/03/67__Wed 1/03/68__Fri 1/03/69
_41__Fri 2/10/67__Sat 2/10/68__Mo 2/10/69
110__Th 4/20/67__Fri 4/19/68__Su 4/20/69
136__Tu 5/16/67__Wed 5/15/68__Fri 5/16/69
171__Tu 6/20/67__Wed 6/19/68__Fri 6/20/69
194__Th 7/13/67__Fri 7/12/68__Su 7/13/69
265__Fri 9/22/67__Sat 9/21/68__Mo 9/22/69
forum refuses to space the text like the Excel sheet does so I tried underscores to get 'em spaced better
Assuming no castings were made on Sunday, we can rule out those days
Anything before 5/67 can probably be ruled out as too early.
Similarly, 9/69 is too late, by then they would be casting E and F heads for 1970 models.
Old Mar 3, 2014 | 09:27 AM
pogo69's Avatar
morgan
mine are original to the block.... number 15, date of 41 and a build date of o4e
Old May 16, 2014 | 08:21 PM
2blu442's Avatar
Chris, I just picked up a pair with Julian date of 132. Once cracked and may or may not be fixable... so I created a post asking if someone has a single they would be willing to sell or trade for.
John
Old Jul 23, 2014 | 10:19 PM
I had opportunity last week to check out the original engine parts from my 29K mile '68 H/O (blown up for the 2nd time in '89 by the original owner).
Was surprised to find a "110" & a "135" head. I always "assumed" they would be the originals & tried to contact the original owner to confirm but was unsuccessful.
8M409964 06A - Hern Olds Bedford, OH
I wonder if the "136" on the list should be "135"?
Old Jul 24, 2014 | 07:00 AM
72xw30's Avatar
My newly acquired 05D built 68 H/O has D heads that both have a casting date of 110.
Cheers,
Sam
Old Jul 24, 2014 | 07:57 AM
camshaw's Avatar
I need a set of Ds,keep your eyes open folks....
Old Jul 26, 2014 | 05:53 PM
Octania's Avatar
Bottom side, center, intake side- among the pushrod holes.
too small to make out in your pics.
"Ø110Ø" and "Ø135Ø" in post #12 above
Also typically topside, far end on your right as you face the engine from the side, just under valve cover gasket.
It typically has a screw head [ Ø ] visible each side, and of course will vary from 1 to 366.
Old Jul 27, 2014 | 04:40 PM
64Rocket's Avatar
The set of "D's" I have are date code #110.
Of which they are for sale.
Gene
Old Jul 27, 2014 | 04:56 PM
camshaw's Avatar
how much for the ds?
how much dean?
Old Jul 27, 2014 | 11:12 PM
64Rocket's Avatar
PM me for info
Gene
Jun 11, 2014 03:28 PM
Al2011
Apr 18, 2014 11:14 AM
dustyd
Jul 1, 2013 09:50 AM
455man
May 4, 2013 11:58 AM
Hal Robinson
Jan 28, 2012 01:32 PM
