cam selection
Old May 23, 2015 | 06:08 PM
kjr442's Avatar
Kjr442
cam selection
please help me select a good cam for my 455 build. I am using big valve E heads. 30 over high compression pistons that are comparable to the 1970 455 in a 442. any help with this selection would be appreciated. my goal is to have something close to a stock 1970 442.
Old May 23, 2015 | 06:27 PM
cutlassefi's Avatar
None of us can recommend a thing until you give us the rest of your combo as well as exactly what piston you're using.
Old May 23, 2015 | 09:40 PM
kjr442's Avatar
Kjr442
I just need to know a brand, and part number for a cam that is a good replacement for a 70 442. this is just a stock build.
Old May 24, 2015 | 12:54 AM
Why are you asking the same question in multiple threads?
Old May 24, 2015 | 05:50 AM
cutlassefi's Avatar
I'd still like to know the piston you'll be using.
Old May 24, 2015 | 03:07 PM
kjr442's Avatar
Kjr442
I didn't think I was getting the right answers. I am quite sure there are guys here that have bought, and used a new, stock replacement cam for their 70 442. I was just looking for a good brand name, and part number.
Old May 24, 2015 | 03:08 PM
kjr442's Avatar
Kjr442
I will get you that information. thanks
Old May 24, 2015 | 05:21 PM
Meanwhile, Google Crane Cams Muscle Car Camshaft Guide on enginelabs.com. Lots of good stuff in there and lots of reference to Crane's Blueprint Series which sounds like it's right up your alley.
Old May 24, 2015 | 05:23 PM
z11375ss's Avatar
Senior Moment Member
A big one. One that rumbles. There, that's your answer.
Old May 24, 2015 | 06:22 PM
kjr442's Avatar
Kjr442
LOL thank you. That sounds just right.
Old May 24, 2015 | 06:26 PM
kjr442's Avatar
Kjr442
Thank you. Patiently waiting for more feedback. LOL But I will look at Crane.
Old May 25, 2015 | 06:31 AM
cutlassefi's Avatar
Depending on the piston being used I'd probably do an Erson Hi Flow 1, 228/228@.050 with .504 lift on both.
Old May 25, 2015 | 07:00 AM
69Chrgr's Avatar
Cam selectiion
He is using a stock dished flat top, stock rods and crank. All bottom end is
factory OEM specs. That should be enough info on cam spec suggestions.
Old May 25, 2015 | 07:09 AM
cutlassefi's Avatar
Hmmmm I wasn't sure the original style small dish pistons were still available. The only ones I know of are the 13cc Federal Moguls that have a 1.720 cd. With 80cc heads that would give him about 9.5:1. The cam I mentioned would work with that, but I wouldn't go any bigger.
Old May 25, 2015 | 07:32 AM
69Chrgr's Avatar
Thank you sir.
Old May 26, 2015 | 08:48 AM
kjr442's Avatar
Kjr442
This is a NOS set of Pistons that I bought from another member here. They are Perfect Circle Brand Pistons .30 they are at the machine shop, having the rods pressed on. I can get the other specks later today.
I did some searching on my own. The stock part number for the cam is 400165
And I now have those specks to go off of.
Old May 27, 2015 | 06:23 AM
edzolz's Avatar
Those pistons are 14cc dish. Cast and are NOS from many years back. I had them since the Dallas NTOC hosted the nationals the first time. (1990 ?)
Old May 27, 2015 | 06:57 AM
kjr442's Avatar
Kjr442
Thanks Ed. I think this is going to make a good engine.
nofiveo
Jun 14, 2019 07:26 PM
hazzmatte
Oct 13, 2010 06:19 PM
Wireman134
Aug 22, 2008 08:28 PM
ijasond
May 13, 2008 08:27 AM
bobolds
Mar 26, 2007 02:45 PM
