Cam profile
Old Feb 15, 2007 | 06:41 PM
Deltarocket's Avatar
Cam profile
Does anybody know what's the biggest cam one can go with, without having to change from the stock push rod, rocker pivot bridge combo ?
I have a 74' 455
Old Feb 15, 2007 | 07:30 PM
2blu442's Avatar
I don't, and if you don't get a reply here you might check out realoldspower.com They have a section for engine building. A warning though, some of the ROP guys can be downright rude, so don't take it personal. I visit several car sites and the guys here are much more friendly and helpful than the other sites I've found. John
Old Feb 15, 2007 | 08:05 PM
Thanks for the heads up.
Old Feb 16, 2007 | 05:29 AM
70Wcars's Avatar
I am currently running a .499 lift cam in my 4-speed car with stock ' type " rockers. I use the Elgin or Pioneer rockers that have a steel strap and individual pivots instead of the stock Alum. bridge. That way I can adjust the valvetrain somewhat using shims. I always convert to a CM pushrod with any cam change. Let me know what your engine combo is looking like, and I would be glad to make some cam suggestions.
Old Feb 16, 2007 | 07:13 AM
Being that this is a low compression engine, I would like to go with a camshaft that produces a little more cylinder pressure. I don't want it to lope much, as this is going in a full size car. I was think of something with about 210/217 duration and about 480/490 lift. I just got thru buying a complete set of the stock aluminum pivot bridge, and I want to keep the original stock push rods. It's been years since I messed with an Oldsmobile, I use to know the answer to this question, now I'm all small block chevy
Thanks for all the help !!
Old Feb 16, 2007 | 12:04 PM
70Wcars's Avatar
That should be a good choice for some power and easy on the V-train. If you need to adjust the lifter pre-load, you can cut the alum pivots down on a belt sander a few thou. Just be careful not to have one side too much shorter than the other, or they will crack from the offset. Voice of experience here.
gearheads78
Aug 18, 2011 08:27 PM
jensenracing77
May 4, 2011 04:48 PM
nickd
Site Help
Apr 12, 2009 08:06 AM
lovelavc
Site Help
Mar 16, 2009 08:14 PM
Olds64
Sep 15, 2007 07:02 AM
