455 ate a cam lobe
455 ate a cam lobe
i bought a used 455 that was 'rebuilt'. In checking it out I found a cam lobe wiped out and the lifter is 3/16 shorter than all the rest. Should i take the short block in and get all new bearings installed?
i thought so. The cylinder bores look new. It's got keith black hyp. pistons so I want to fix it right. I've never installed engine and want to get it right before its in the car. Thanks for the replies ron
yes thats the one. I will take it in have them work on it. I never thought about the pistons, kind of a bummer. I hope the maw's dont kick in too bad. I'm checking edel. heads, stroker kits. Somebody stop me. The resto going slow but i knew that when i started. Frame is blasted painted, new suspension, rebuilt type O 3.42's. Hoping to get motor trans complete. Body is next.
Don't slit your wrists yet. Take it apart clean/inspect your assembly. "You" clean/wire brush oil galies. Look good at your cam bearings and oil pump. Maybe new rings, but probably new bearings. Follow instructions on cam break in. Zinc is your friend. Good luck, Ken
I found 2 lobes JUST starting to go when I removed the engine to fix a oil leak. Since I had the intake, heads, and oil pan off I figured I would re-lube the lifters with assembly paste. Had to lifters that didn't want to come out of the block. I fixed it by going roller!
Soon as I get my tax money back, engine will go in for bearing and whatever it needs. I am thinking I will go roller. Does anybody do crankshaft cap straps anymore or is that a waste? Just thinking about some small things to make it a better engine. Any suggestions.
Depends on the anticipated hp level. But if you do that, you'll need to use studs then check the line bore and most probably have to have it align honed.
it has studs already. Didn't know if anyone makes or use straps anymore. It also has a milodon gear drive. I don't think I'm going to use that. I haven't heard very many good things about them. Plus it would need electric fuel pump, I would rather have mech. fuel pump. Any have any experience with the gear drives?
