394 engine color--
Old Mar 3, 2011 | 01:40 PM
trackz man's Avatar
394 engine color--
So I was told by several auto parts shops that since Olds Red is not available to paint the block, just to use Ford Red. I think my grandfather would roll over in his grave if he knew that I bought FORD RED to use on a Oldsmobile engine
Any suggestions where to get OLDS RED???
Old Mar 3, 2011 | 05:35 PM
T butter's Avatar
The closest I came to OE was Dupli-Color #DE 1653 Red Looks good plus it is Ceramic 500 degree paint . hope this will help.
Tom
Old Mar 3, 2011 | 06:25 PM
62Starfire63's Avatar
I just painted my 394 and looked around for something other then ford red, and came up with the same as already mentioned Dupli-Color #DE 1653 Red. You can see it listed on their website here http://www.duplicolor.com/products/enginePaint/
This is how it looks, brighter then the ford red.
A few other photos I posted in this thread if you want to see the color more. https://classicoldsmobile.com/forums...-begins-2.html
Otherwise I beleive Fusick sells an engine paint the correct red color.
Old Mar 4, 2011 | 02:47 AM
Yellowstatue's Avatar
What's my car, that you made, doing in your avatar???
Old Mar 4, 2011 | 11:23 AM
66nicole66's Avatar
I want to repaint the valve covers fo my 68-er Delmont and seached and searched the internet but I found "Rocket Red" from VHT.
So famous that I was able to order it at my place, in the Netherlands
Old Mar 4, 2011 | 11:36 AM
trackz man's Avatar
That is a killer paint job- I will post some pics as we progress again- thanks again for the help -we are going to use the same as you did- What color and paint did you use on the valve covers and exhaust manifolds? Did you also paint your roto-hydramatic?
Old Mar 4, 2011 | 08:58 PM
The paint for the manifolds I beleive was VHT high temp cast iron color, valve covers I disposed of the paint cans and can't remember. And yes, I painted the transmission...
I forgot I had that photo/avatar and I came across it while organizing. Thought it seemed like a suitable avatar for an Olds website!
Old Mar 17, 2011 | 04:17 PM
trackz man's Avatar
Just painted the exhaust manifolds-the same as you mentioned above. That is the color that we actually had in the cabinet. We painted the transmission with Eastwood Aluma-Blast and kept the filler tube and breather line- underhood black. Looks killer. Will send some pics when my son gets a chance. The firewall and front suspension is now underhood black as well...
Old Nov 11, 2016 | 11:29 AM
Rusty Carlson's Avatar
engine paint
Are all engines red?
Otherwise I beleive Fusick sells an engine paint the correct red color.[/QUOTE]
Old Nov 11, 2016 | 11:30 AM
Great job!!
Old Nov 11, 2016 | 11:36 AM
Oldsfan's Avatar
Only the high compression ones. The low compression ones are a lighter green.
Big Joe P
Jan 18, 2013 08:37 AM
jvock6
Apr 30, 2012 10:31 PM
trackz man
Dec 13, 2010 12:45 PM
Sixoh
Mar 7, 2007 06:18 AM
