Headlight Tweak: Is this even possible?
Old Nov 9, 2007 | 10:09 PM
KSparkuhl's Avatar
Curious to know if it's even possible to tweak the headlight's electrical configuration so that all four headlights will come on when the brights are on. I'm finding on late-night road trips that it would be nice to have the low beams on as well for added illumination. I'm using Sylvania Silverstars as it is, but it seems a waste to have the lows off when you're trying to get more illumination on the roadway... and besides... the added cool factor of having all four headlights on would be icing on the cake.
Any suggestions on how to do this, or would it be super involved?
Old Nov 10, 2007 | 05:12 AM
ozoneblue's Avatar
Its easy to do. Just jump the two power wires at dimmer switch with a toggle switch. With lights on high flip the switch,I also added another small indicator light so I would know.This works good on my 90 chevy PU mainly because the plastic lenses have gotten so fogged over the years
Old Nov 12, 2007 | 01:14 PM
KSparkuhl's Avatar
Thanks for the suggestion Ozone. Any tips for tracing out the power wires for the low-beams?
Old Nov 12, 2007 | 04:52 PM
ozoneblue's Avatar
The colors use to be light green & dark green ,There should only 3 wires on dimmer switch 1 is power With lights on the other 2 for lights
Old Nov 13, 2007 | 12:15 PM
Redog's Avatar
You can also pull the relay out and stick a small piece of electrical tape between the contacts.
A lot of guys have done that on Aleromod.com
Gmcdually
Apr 15, 2015 08:35 AM
jeffreyalman
Jul 23, 2009 04:38 PM
ent72olds
Jul 21, 2009 10:03 PM
Lady72nRob71
Feb 28, 2008 03:16 AM
Nailhead 88
Feb 21, 2008 08:52 AM
