15 to 16 inch
15 to 16 inch
My 1999 Alero, has 15 inch tires on it. I can buy a set of 16 inch rims a tires from a 2002 Alero. Can I use these, if so will it hurt or change anything, such as the speedo ?
Your original tires size is P215-60-15, going to the optional 16" wheel should give a factory size P225-50-16 which will put you about .300 smaller in rolling diameter,it should not change your speedo to much, just slightly fast reading, also it should slightly handle better and give it a wider stance looking at it.
Just for reference front view of my Alero GLS (16" factory)
dz442
Sep 6, 2019 03:55 PM
