Correct code for 65 or 66 14x6 rims
Old Mar 27, 2013 | 07:09 AM
jim larson's Avatar
What would be the correct code for the standard 14x6 steel rim from 65 or 66?
Thinking it might be 6, A, R, or 6 A. This would be the rim with a 1.00" offset or a 4.5" backspace, I think. Thanks.
Old Mar 27, 2013 | 08:35 PM
rcorrigan5's Avatar
Randy C.
From what I've seen on other posts, and what the assembly manual says for my '68, the correct code is "R".
Randy C.
Old Mar 28, 2013 | 06:26 AM
wmachine's Avatar
Trying to remember member
First we'll presume you mean F85 here. "Standard" throws things off a bit.
The "standard" 14" wheel for '66-'69 was 14 x 5, code A, then XC midyear '68-'69.
The "standard" wheel for the '65-'68 442 was the heavy duty 14 x 6, code R.
Old Mar 28, 2013 | 01:06 PM
jim larson's Avatar
Yes I kind of used the standard term to lightly, So then in 65 and 66 the 442 used code R exclusively? I think this is exactly the same rim as came on the 66 chevelle SS and the 65-66 chevelle wagon with HD suspension (although chevy used a different code, in 66 chevy used 2 different codes, then a different one in 67 and changed again in 66, all for the exact same rim, gm 3871919). I was thinking that some of the 65-66 olds vista wagons came with the 14x6 rim with a 1.00 offset As well as some of the f85 with HD suspension. I know I pulled a set of rims off a 67 vista cruiser with a code of 6 A3 that were 14x6JK, with a 1.00 offset, dated 67; but I don't know if they were original.
I was also told that at some time the J-88 also used a 14x6 rim with code A.
I currently have 3 of rims in the garage, code A., 14x6 JK (6" is bead to bead), 1.00 offset, center section stamped gm 64 or gm 65 (Not sure which).
I have also read that some of the Pontiac's, gto for example used the same rim, although the stamped code could be different. Just read last night from a Pontiac restoration guide that they used gm 3871919 for the 64-67 got; but you know there are lots of errors out there on the internet.
LJA72
Jan 31, 2014 08:02 PM
jim larson
Mar 27, 2013 06:25 PM
MrLightning
May 17, 2012 04:58 PM
MrLightning
May 1, 2012 02:46 PM
dan1s
May 4, 2009 06:10 PM
