Click Here
Rim Identification
Old December 20th, 2016, 12:03 AM
VI Cutty's Avatar
Rim Identification
I've got three rims that came with a '70 Cutlass S I've just bought and I'm trying to identify them. Obviously 14x6 SS2's but the wheel centre is further out than the ones on my '71 Cutlass. Unfortunately there are only the three, the fourth was "smoked", apparently.
From what I'm seeing on the Oldsmobility wheel page (http://www.oldsmobility.com/old/superstock.htm) these appear to be for the '68 442/HO.
Don't let the colour mislead you, they've been stripped and repainted.
Also, what would these be worth?
VI Cutty is offline
Old December 20th, 2016, 08:49 AM
Randy C.
rcorrigan5's Avatar
SSII rims for a '69 A-body car, LS code, 14 X 6 instead of the 14 X 7 SSII rims on your '71 which probably explains why the center is further out. Wheel pictured is dated December 6, 1968.
Randy C.
rcorrigan5 is offline
Old December 20th, 2016, 10:52 AM
To clarify, the center isn't "further out", the later wheel is wider. Since both have zero offset, the center will certainly be "closer" to the outboard face AND also closer to the inboard face on the narrower wheel.
joe_padavano is offline
Old December 20th, 2016, 11:19 AM
svnt442's Avatar
Also the Hurst wheels were 15x7" I believe.
svnt442 is offline
Old December 20th, 2016, 04:10 PM
VI Cutty's Avatar
Makes sense. The date helps a lot too.
Didn't consider the 7" rims and where that extra inch would be. Had meant to check the offset/backspacing but no need now!
The Oldsmobility page seems to suggest that there was the 15 x 7 wheel but also a 14 x 6 wheel hence my uncertainty. I know the guy I'm buying the car from got quite a few parts off a '69, possibly a 442. The spare 350 has number 5 heads so probably from the same car.
VI Cutty is offline
Old December 20th, 2016, 04:13 PM
Half an inch on each side.
You'll know the 69 H/O rims when you see them. Note the much wider, chrome rim.
BigAl72
March 16th, 2009 06:16 AM
audiodox
February 13th, 2009 01:22 PM
Toro68
October 13th, 2008 12:21 PM
Wasted
July 5th, 2008 07:28 AM
SMOKEYMTNKUSTOMS
April 21st, 2006 04:45 PM
Quick Reply: Rim Identification
