Click Here
Different rims and same tires...need an alignment?
Old September 24th, 2011, 05:04 PM
yeahbuddy's Avatar
I picked up a set of 15" x 7 olds rally wheels this weekend. Tires that came on then are cracked so I am going to use the tires on my current wheels. I had an alignment done about three months ago. Question is if I swap rims and rotate tires, do I need an alignment? Thanks
yeahbuddy is offline
Old September 24th, 2011, 05:53 PM
CQR
CQR's Avatar
Wheels, tires and location will not affect alignment angles.
The exception being if you change the stance of the car by putting smaller front tires on the rear and larger rear tires to the front. Then it could change your caster somewhat, but that angle won't wear the tires and besides that would look strange anyhow.
CQR is offline
Oldssupreme
Brakes/Hydraulic Systems
August 1st, 2014 03:49 AM
RAMBOW
July 29th, 2013 05:32 PM
oldsguybry
Wheels and Tires
19
February 16th, 2013 09:14 PM
costpenn
January 17th, 2012 04:34 PM
jeffreyalman
June 6th, 2009 06:28 PM
Quick Reply: Different rims and same tires...need an alignment?
