57 Olds fuel pump
Old August 31st, 2014, 04:39 PM
Mark57's Avatar
57 Olds fuel pump
Had an issue with the car not starting and found the pump wasn't pushing any gas to the carb. Made sure the pump was getting gas but it just wasn't pushing any out. I found the actuator arm was hard to move so I pulled it appart. I found one of the valves in the vacuum chamber had come out and was binding up against the diaphragm keeping it from moving freely. I have attached a picture.
The question I have is that my pump is an AC M3416, stamped on the mounting flange. I can't find a re-build kit specific to this pump and am wondering if it is the right pump for the car. Fusick show the pump should be an AC 4317. Any ides??
Mark
Mark57 is offline
Old September 1st, 2014, 03:57 PM
mpolds's Avatar
1955 - 1958 Olds Fuel Pump
The correct # s are 4317 officially for 1955 - 1957 and 4646 for 1958
--- those are the AC #s -- and they can actually be used for one another.
They, however, are IMPOSSIBLE to find BRAND NEW -- they are in the world of rebuilts or kits only.....
The # you have is on the push rod -- and that is only a "partial" number -- not the fuel pump # -- the 4317 whould be on the flange where the fuel pump mounting gasket mounts....
You will at this point have to go with a fuel pump kit -- if you want to tackle
rebuilding it yourself.....
mpolds is online now
Old September 1st, 2014, 04:02 PM
Mark57's Avatar
I now have found a re-build kit for the pump I have but I'm not sure if I should re-build it or buy the appropriate pump. Not so much to keep it stock but to make sure the pump has the right performance for the car. I have emailed Fusick to see if they have any data on this pump. I'm wondering if someone may have swapped the pump and possibly changed the arm on it to suit??
Mark
Mark57 is offline
Old September 1st, 2014, 04:05 PM
Mark57's Avatar
The # M3416 is on the flange as shown in the picture. I realize that I will need a kit but don't want to waste my money on a kit for the wrong pump.
I have attached a picture that shows the marking on the flange.
Mark57 is offline
Old September 1st, 2014, 04:08 PM
mpolds's Avatar
Carter had a number system with an "M" and four digits -- any chance this is a Carter
Fuel Pump???? I don't know the Carter # off the top of my head -- but I do have some interchanges -- and could check to see what the Carter # is....
Let me know if this is a "Carter" fuel pump?!?!?!?
Old September 1st, 2014, 04:17 PM
Mark57's Avatar
Its definitely AC as shown in the first set of pictures.
Mark57 is offline
Old September 1st, 2014, 04:26 PM
Mark57's Avatar
If I could confirm this pump has the same properties as the listed pump I will complete the re-build as I have located a kit.
Mark
Mark57 is offline
Old September 2nd, 2014, 05:55 PM
67 Cutlass Freak's Avatar
I've got the guy for you. I would never use anyone else.
Hal Houghton, The Classic Preservation Coalition 518- 374-5078/ 518-366-8405 cel. This guy really nows his pumps. He sold me a kit for my 394, wasn't too difficult to rebuild, but I messed something up. It was leaking. I took it off, sent it to him and he didn't even charge me to rebuild it right. Now that's customer service. Give him a call. If you really want to attempt to rebuild it yourself, I could post up the instructions.
67 Cutlass Freak is offline
Old September 2nd, 2014, 06:08 PM
Mark57's Avatar
Thanks Mr Freak;
I actually found him on the net and sent him an email yesterday. Apparently the pump, or part of the pump I have is the same as an AC 6585 which was on the 61 Oldsmobile. So it looks like possibly someone has used the glass bowl section to go with this pump. He says he has a rebuild kit for me, just waiting to hear back. He has confirmed the pump volume should be about the same.
Thanks Again
Mark
Mark57 is offline
Old September 2nd, 2014, 08:41 PM
I sent you a PM with rebuild instructions. Tell Hal I said hi. Thanks, Dave
Old September 4th, 2014, 01:56 PM
stratoblues's Avatar
Hal is the guy for info on the old pumps. I bought a rebuild kit from him and was able to rebuild mine with success. He is very helpful. His kits are cheaper than Fusick because you will have to disassemble the diaphragm. Fusick sells the kit with the new diaphragm assembled. A little more challenging.
stratoblues is offline
Old September 4th, 2014, 02:57 PM
Mark57's Avatar
Hal
I ordered a kit from Hal today, I will let you know how it goes. Thanks for your help guys.
Mark
Mark57 is offline
Old September 21st, 2014, 08:35 AM
Mark57's Avatar
Success!
I received the re-build kit from Hal this week and rebuilt the pump.
I had to rig up my arbor press with a pin small enough to push the rod through the diaphragm plates which was a bit challenging. Followed his directions and all went well. Definitely a job to take your time with!!
Mark
Mark57 is offline
Old September 22nd, 2014, 04:13 PM
Mark glad everything went well for you. Hal really is a good guy. Hard to find people that really want to help you, and charge a fair price nowadays. When I pressed mine together we used a bit from a brake line flaring kit in the press. Now you need to post up some photos of your car ... please.
Old September 23rd, 2014, 02:37 PM
Mark57's Avatar
If you go to this link or my profile I have some pictures there in my album. There is a picture of my current truck project as well.
https://classicoldsmobile.com/forums...+starfire.html
Mark
Mark57 is offline
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
mefirst72
February 10th, 2013 06:37 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
sshriber
March 22nd, 2010 06:16 PM
Quick Reply: 57 Olds fuel pump
