Oil pan removal 57 Olds 98
Old May 12, 2010 | 06:56 AM
Fletch's Avatar
Looked for old thread on pan removal.. Not able to find.
Front seal on 371 is now leaking.... Rats !! Anyone found an easy way to drop pan.
I like the manual/ do not mind reading.... but. anyone removed one lately
Fletch
Old May 12, 2010 | 08:32 AM
citcapp's Avatar
You can do it by droping the stearing linkage, Unbolt it from the frame on the passenger side and pull it down as far as you can then cran the wheel to the left and the pan will clear. Thats what I did on mine. Oh and if you have single exhaust remove the crossover exhaust
Old May 12, 2010 | 11:19 AM
Fletch's Avatar
Thanks Citcapp!! I have about 3 k on motor, sat for a long while... thus the front seal dried out... While I have your attention::
A fast way to fix a pesky fuel gage.
New sender from Fusick... reads 3/4 when full (24gal?)... when 1/4 indicated ,takes 11 gallons to her up..Tank has no bumps or bends..
Thanks again,
Fletch
Old May 12, 2010 | 02:25 PM
citcapp's Avatar
I would like to figure this one out myself. I have almost the same problem and others I have talked to have the same issue. If fact when I filled it up today it was reading a 1/4 tank and took 12.2 gallons. I have gotten into the habit of just filling it up at a 1/4 tank just to be safe.
Old May 12, 2010 | 11:00 PM
jaymann's Avatar
hmmm. I was just about to order the sender from Fusick for my '56....are you both thinking it's the new sender that is at fault?
Old May 13, 2010 | 03:15 AM
Yellowstatue's Avatar
Guage resistance is 90 ohms...before you install guage hook it up to the car and ground the frame of the guage to the car and manually move float and check guage reading at different float heights...might have to bend float rod to get readings at right level...
Old May 13, 2010 | 06:41 AM
Fletch's Avatar
Good idea.. Thanks.. Fusiks sender (I believe ) is OK.. I was trying to get around pulling the panel....
But if the resistance is 90ohms( thanks for the info) I will start by chasing a good ground first...
Nice to know someone else has that problem .
Thanks Citcapp and Yellowstone.
Fletch
Old May 13, 2010 | 06:43 AM
Fletch's Avatar
Opps ..Yellowstatue/ not the park !
Old May 13, 2010 | 08:52 AM
jaymann's Avatar
What did you guys do for a filter on the pickup tube? I've talked to Fusick's and they say no one is reproducing them
Old May 13, 2010 | 03:38 PM
Fletch's Avatar
Not a tough issue. I have used alot of after market pick-up tubes from Jegs on Mellon pumps. Make sure you tack weld to pump after you position strainer.
Fletch
Old May 13, 2010 | 08:16 PM
59-59-59's Avatar
90 Ohms? I could of sworn it was 35.. Anyway check the ground as I had faulty readings until I ran a ground wire directly from the sender to a known good ground
Old May 17, 2010 | 07:23 AM
Fletch's Avatar
Thanks...
Fletch
Old May 18, 2010 | 12:40 PM
jaymann's Avatar
I just bought this sender for my 56 off of EBAY
http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWAX:IT
...I'll report back how well it works.
Kaline
Apr 18, 2022 03:35 PM
Stevec
Mar 24, 2012 02:25 PM
Lawndog
Aug 21, 2011 10:14 PM
leadfoot067
Dec 3, 2010 06:11 PM
