pertronix question
Old June 21st, 2016, 06:52 AM
fatback's Avatar
pertronix question
got a question for all you guys that changed over to pertronix ignition. what else did you have to change. the coil I'm sure, how bout the plugs? plug wires? cap? rotor? do you gap the plugs wider?
fatback is offline
Old June 21st, 2016, 07:00 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I changed to the Pertronix coil which I believe is about 40,000 volts. There is no need to change wires. I did widen the gap on my plugs to about 40 thousandths which is probably not necessary. The basic Pertronix is not an HEI but rather a breakerless ignition. Just be sure the cap, wires and rotor and in good condition and you should be good to go.
redoldsman is offline
Old June 21st, 2016, 07:17 AM
All tuneup settings remain the same as do the ignition parts. It is a points replacement set up, so all your accomplishing is not having to set points periodically. Use the coil that goes with the pertronics ignition you select.
oldcutlass is online now
Old June 21st, 2016, 08:10 AM
jaunty75's Avatar
Nothing.
Remember, as noted by oldcutlass, all you've done is change the points to an electronic system. You have NOT changed to electronic ignition. So all other settings (timing, plug gap) and components (plugs, wires, coil, distributor cap) remain the same.
I did this conversion on both my '67 Delta 88 and '73 Custom Cruiser (which I no longer own). It was not difficult in either case, and both cars run like a top.
jaunty75 is online now
Old June 21st, 2016, 08:20 AM
What Eric and Jaunty said.
MDchanic is offline
Old June 21st, 2016, 08:46 AM
Randy C.
rcorrigan5's Avatar
X2 or 3 now. I did the same thing with my '68 4-4-2 (in 2010) and '71 Corvette (in 2003). Coils are original for both and plugs and wires are replacements for the originals. No problems.
Randy C.
rcorrigan5 is online now
Old June 21st, 2016, 09:30 AM
oldsmobiledave's Avatar
coil
Randy C.
I was told that Pertronix ignition requires that you run their coil. Is that correct or not?
oldsmobiledave is offline
Old June 21st, 2016, 09:33 AM
brown7373's Avatar
X4. I have converted numerous cars and only once changed to the Pertronix coil, on a 69 Vette 350/350 11:1 compression and 6000 red line. I always used a new distributor cap and rotor and did new plugs, and stock wires if they needed replacement. They DO NOT deliver more power, but rather maintain a fresh tune up all the time.
brown7373 is offline
Old June 21st, 2016, 09:40 AM
It was the same for Pertronix I The resistance wire can be used in place of the resistor for stock coil, and bypassed for flame thrower coil.
Old June 21st, 2016, 10:28 AM
Not.
MDchanic is offline
Old June 21st, 2016, 10:36 AM
If you want to get a bit more power, I recommend using theirs as you can run a full 12v.
Old June 21st, 2016, 12:41 PM
redoldsman's Avatar
The Pertronix coil only cost $40.00. That is pretty cheap insurance to me.
Old June 21st, 2016, 01:29 PM
fatback's Avatar
thanks fellers
fatback is offline
Old June 21st, 2016, 02:02 PM
Not to bust your chops too much, but...
Insurance against what?
You're replacing an American-made GM factory coil that's performed well for half a century with a new Chinese-made (Pertronix does not list country of origin for its coils on its web site, so we can ASSume) coil that is claimed to be better in advertising materials.
If you want to run one of those coils, that's certainly your choice, but I'd hesitate to believe that they are necessarily more reliable.
MDchanic is offline
Old June 21st, 2016, 03:20 PM
redoldsman's Avatar
Chops not busted Eric. You do make a good point. Often times I will buy rebuilt over new since the new is going to be Chinese made. I would rather have a good rebuilt USA made unit than a Chinese made one. I had not thought of the made in China aspect.
Old June 21st, 2016, 03:51 PM
68-W46's Avatar
Anyone wired one to an MSD box? What do you do with the resistor wire?
68-W46 is offline
Old June 21st, 2016, 03:57 PM
You would just tape/cap and stow the resistance wire.
Old June 21st, 2016, 04:38 PM
My442's Avatar
Pertronix recommends a full 12 volts to the unit. 2 ways to accomplish:
1. Easier Way - Run a fused wire from the IGN spade on the fuse block to the coil.
2. Cleaner Way - Pull the engine harness and replace the resistor wire with a regular wire.
3. Best Way - Call M&H Electrical and have them make you an engine harness with the "HEI" modification.
My442 is offline
Old June 21st, 2016, 11:12 PM
68-W46's Avatar
thanks good info.....want to put one in my 67....
68-W46 is offline
Old June 22nd, 2016, 08:39 AM
anthonyP's Avatar
Even though it has the preventive overload feature so if you accidently leave the ignition in the on position and the adaptive dwell & start-up sensors, is the Pertronix Ignitor II worth the extra cost over the Ignitor I?
anthonyP is offline
Old June 22nd, 2016, 08:47 AM
The Pertronix III needs no separate trigger magnet - fewer parts = fewer failure points.
MDchanic is offline
Old June 27th, 2016, 04:27 PM
Mark57's Avatar
I put the ignitor III and flame thrower III in my 57 Oldsmobile and have been happy with the results. I did put a new distributor cap, plugs and wires on because it was time.
Mark
Mark57 is offline
Old June 28th, 2016, 07:00 AM
fatback's Avatar
so for my 55 324, which pertronix do I need, 1,2,or 3?
fatback is offline
Old June 28th, 2016, 07:14 AM
redoldsman's Avatar
fatback, I am running a 1 in my 54 and it works perfectly.
Old June 28th, 2016, 07:21 AM
We've all just told you our opinions on that.
MDchanic is offline
Old June 28th, 2016, 09:13 AM
allyolds68's Avatar
And you get a Rev limiter
allyolds68 is offline
Old June 28th, 2016, 01:12 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Nobody has mentioned grounds yet so Ill get on my soap box....GROUNDS. Check them all. The module will be the first thing to go if the grounds are not there and in good shape. Run a dedicated ground from block to frame to firewall back to the battery neg to insure proper operation and longevity of the new module and everything else in the car that depends on 12VDC.
droldsmorland is offline
Old June 30th, 2016, 01:39 PM
Eightbanger's Avatar
More great info.
Eightbanger is offline
Old June 30th, 2016, 05:13 PM
zii
zii's Avatar
I don't think this is true?
If you take a coil that is made for use with resistor and connect it properly through the resistor, and then compare it to a coil that is made for use with full 12 volts and connect this one without a resistor, they should normally give out the same voltage to the spark plugs.
So what's the point of the resistor?
When you start the car, the starter motor draws a lot of amps, and the battery voltage goes lower than the 12 (well, 13.2) volts it usually has.
This causes your 12V coil to get too low voltage and can make your car more difficult to start.
The coil with the resistor however, should, if properly connected, have a bypass wire that now feeds it power without going through the resistor, and therefore the resistored coil will suffer much less from the dropped voltage and your car should be easier to start than with the 12V coil.
So all the manufacturers that put coils with resistors on your cars from factory didn't do it just to mess with you. :P
That being said, I'm not exactly an expert on high performance coils, so I actually have no idea if they too are available with resistors, or if they use other means (capacitors?) to keep your car easy to start.
zii is offline
Old June 30th, 2016, 07:38 PM
I was referring to running volts in my statement. There are many different coils with different output voltages.
Old June 30th, 2016, 09:16 PM
  #31
The ballast resistor is also there as an essential component of the LRC circuit (Inductance, Resistance, Capacitance) of the coil/points/condenser system. Its resistance varies predictably, and significantly, with temperature, which allows it to "self-adjust" to keep the LRC circuit tuned at various RPMs.
A "resistorless" coil very likely has a similar resistor inside of its case.
MDchanic is offline
Old July 2nd, 2016, 05:14 AM
  #32
Mark57's Avatar
Mark
Just to add to this;
After running the Pertronix last season the one thing I noticed this spring is the amount of carbon on the tail pipe. It has basically disappeared and when I ran a can of carb cleaner through it the output was very clean compared to when I had run a can through prior to the Pertronix. That being said I have also been running Lucas Gas additive which could be keeping the combustion chamber cleaner as well. From what I have read if you have a hotter burning spark you should have a cleaner burn, this is what sold me on the III set up.My gas mileage did slightly improve but nothing worth boasting about.
I felt that the ease of the install and the results I have seen it was worth the extra money going to the III set up.
Mark
Mark57 is offline
Old July 3rd, 2016, 02:37 AM
  #33
cmpcpro's Avatar
I just bought the 2 for my 56, I would have bought the 3 but it wasn't available for my car.. I think 57 or 8 is the first year it does..
cmpcpro is offline
Almond900
June 12th, 2016 07:36 AM
TomType1
April 1st, 2014 07:48 PM
Mak
November 19th, 2011 07:55 AM
cessna195
May 15th, 2010 02:35 PM
Chuck C
April 29th, 2004 02:12 PM
Quick Reply: pertronix question
