55 Dual Exhaust
Old April 24th, 2015, 07:20 AM
Brent in Georgia
blento's Avatar
55 Dual Exhaust
There was no dual exhaust option in 55, so there is not enough room to run the exhaust over the axle. The drivers side has the brake lines and the tank is to close for a pipe. My exhaust guy ran them under the axle. The only problem is if I need to change a tire or have it lifted on a frame hoist the tail pipe hangers need to me released so the axle can drop without busting stuff.
Here are the pictures
https://classicoldsmobile.com/forums...1&d=1429884689
https://classicoldsmobile.com/forums...1&d=1429884740
blento is offline
Old April 24th, 2015, 01:27 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I guess I don't understand why he had to run those under the rear end. The 56 had duals available and it is pretty much the same car on the back half. My problem on the 54 is getting by the power steering (it can be done I know). The frame has to be cut to get the exhaust pipe in and the tailpipe out. I am pretty sure Tedd has duals on his 55 convertible. At some point I will probably take the car to my muffler guy and leave it with him for a couple days so he can get it done. I really don't know why because it sounds about right with one Smitty on it.
redoldsman is offline
Old April 24th, 2015, 05:51 PM
Tedd Thompson's Avatar
I also would have my doubts on that under the axle installation. I'm sure that will be a issue on a few speed bumps you will encounter.As Redoldsman said the rear isn't near the problem as is the front of the installation.
Somewhere I had a picture posted of the bottom of a 55(not mine) that shows just how it can be done and takes away all the difficulty of trying to explain all the twist and turns but I cant find it. Love our search feature on this site.Some day when I can get mine up on a lift I'll take a few pictures and post them for people who may need it in the future. If nothing else it would be nice to give to your muffler guy so he doesn't have to reinvent the wheel....Tedd
Tedd Thompson is offline
Old April 24th, 2015, 07:31 PM
redoldsman's Avatar
I would really like to see those pictures if you can find them Tedd. I don't think my muffler guy has a plazma cutter to cut the frame. I don't really want it cut with a torch. I can probably go over and get Richard (Gearshead78) to cut it for me. That could be a project for next winter.
Old April 25th, 2015, 07:56 AM
Other than cosmetics I wouldn't worry about using a torch. The cuts are in the web of the frame and if done quickly there won't be enough heat transfer to hurt anything, it's a very large thick frame..... Tedd
Old April 25th, 2015, 04:19 PM
redoldsman's Avatar
Thanks Tedd. I know the convertible frame is like a section from a bridge. I was more concerned about cosmetics. I don't know why since I am the only one that ever sees under there. There really I some thick heavy steel under there.
Old April 27th, 2015, 06:22 AM
twintracks's Avatar
The suspension will unload when cresting a hill at speed as well. It doesn't have to go airborne to do it. That can't be the best solution.
twintracks is offline
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
dynamic88builder
January 24th, 2006 10:52 AM
copper128
March 21st, 2004 09:43 PM
Quick Reply: 55 Dual Exhaust
