Need Help With Trans Filter
Old Nov 24, 2008 | 12:01 PM
Curtis Detzel's Avatar
I have a 64 F 85. I can not find the correct AT filter. It is not the on(AT P P/N B27) listed at the many Auto Parts stores I have been to. I can't say for shure that it is the orig. trans but have no reason to think otherwise. The filter that I took out has a straight Tube, triangular base and a rasied resavour along the long end of the triangle. The trans appears to be a Jetaway.
Old Nov 24, 2008 | 12:03 PM
You should be able to get a transmission filter from Fatsco Transmissions.
http://www.fatsco.com/
Old Nov 24, 2008 | 01:53 PM
Oldsguy's Avatar
Past Administrator
Curtis, welcome to our site, I hope you find your filter.
Old Dec 2, 2008 | 10:23 AM
Denm33's Avatar
I have a 64 F85 Cutlass. 330 4barrel.
I can look it up for you. The last one that I bought was about 20 years ago, (the car is rarely driven out of the garage.) But I kept the box so I can give you a part number. I think it was a FRAM. I will post part number asap
Old Dec 2, 2008 | 02:44 PM
88 coupe's Avatar
Junior Member
Originally Posted by Curtis Detzel
........ The filter that I took out has a straight Tube, triangular base and a rasied resavour along the long end of the triangle .........
Norm
Old Dec 2, 2008 | 05:00 PM
Something like this (64-69 are the same)?
http://www.partsamerica.com/productd...e=1158&PTSet=A
billmerbach
Jan 21, 2014 04:55 PM
davidstereo
May 14, 2012 08:09 PM
DreWRoolZ
Transmission
Oct 6, 2011 08:46 AM
