Z Bar installation complication
Old Apr 17, 2013 | 12:44 PM
TWP442's Avatar
Im trying to convert my 1971 442 to a manual trans. I bought a conversion kit but unfortunately the z bar is incorrect. However, the mount on the block seems to be a few inches too far forward from the mount on the frame. What could be the cause of this? Also, most of the conversion kits seem to have the mount being a 1/2" thread, while the one on my block is 3/8".
I have a cheap set of headers on the car now that i believe are the reason its difficult for the z bar to get into place, but even with correct headers the mounts seem like they are going to be too far apart. Any recommendations? Thanks!
Old Apr 17, 2013 | 02:25 PM
don71's Avatar
same but different
I've never done this swap but I wanted to point out this post with a bunch of pictures. Hope this helps. https://classicoldsmobile.com/forums...nfo-trans.html
Old Apr 17, 2013 | 07:48 PM
TWP442's Avatar
Thank you so much, Im going to see if i have that hole drilled out tomorrow. Ive been looking at the flowtech ceramic headers since they are affordable, will they clear the z bar?
Old Apr 17, 2013 | 07:51 PM
Run to Rund's Avatar
You are trying to use the hole for the starter brace. It is on an "ear" hanging from the block. You want the bigger threaded hole several inches farther back; it goes right into the block, not an ear.
Old Apr 17, 2013 | 11:27 PM
RAMBOW's Avatar
Ben
I would highly recommend you forget the flowtechs and buy a set of the Hooker Comp headers.
I was looking really hard at the flowtechs for my build due to the price- But at the advice of another member i shelled out a little bit more ($240) for the hookers.... MUCH better value- nice thick flanges- quality welds.
I've seen Chevy flowtech's in person and they aren't even remotely as nice as these hookers. Well worth the extra $100.
Old Apr 18, 2013 | 03:27 AM
TWP442's Avatar
Did the hookers fit in without any problems? Clearing the Z bar (if your's is a manual), proportioning valve, etc.
Old Apr 18, 2013 | 11:22 AM
TWP442's Avatar
Well i found out i have an Fa block without the z bar pivot. Is there some sort of bracket available that I could purchase or am i sol and have to make one?
Old Apr 18, 2013 | 02:02 PM
joesw31's Avatar
I seen people make brackets that fasten to the side of the block, then, attache the ball stud
GothamCity
Aug 5, 2007 06:29 PM
Oldsproject
Jul 1, 2007 06:05 PM
2 door cut
May 14, 2007 07:52 AM
72RocketPower
Jun 30, 2006 01:36 PM
Chris L.
May 28, 2004 09:44 AM
