68 442 4-speed trans mount
Old Aug 12, 2012 | 09:03 PM
gearheads78's Avatar
car guy
Working on a car I need a new mount for. I thought I could just pick up a cheapy auto part store TH350 mount (maybe I still can) but both Orielly and Autozone say automatic with no listing for a 4-speed. I don't have a old one to compare to.
I was looking at the PartsPlace catalog and they list a specific part number for 4-speed but when I checked to see if auto uses the same part number it lists a different number but says fits auto or std trans in the description.
Old Aug 12, 2012 | 09:07 PM
ah64pilot's Avatar
Rich here's an idea, have Joe take a pic and send it to you. Then compare a new Energy suspension polyurethane mount. If that'll work could you use it? They're cheap.
Old Aug 12, 2012 | 09:29 PM
car guy
Fusiks catalog finally down loaded and they show one for TH400 and one for everything else so I should be able to grab a cheap rubber mount to get it on the road for now.
Old Aug 12, 2012 | 09:34 PM
ah64pilot's Avatar
Good deal! I guess if it doesn't work you're only out a couple of bucks. I know the motor mounts are like $6 each or something like that.
Old Aug 13, 2012 | 02:29 AM
allyolds68's Avatar
I used the Energy suspension polyurethane mount. Don't use the metal spacer that comes in the kit or the trans will sit too high and the driveshaft will rub the tunnel.
Old Aug 13, 2012 | 06:58 AM
Eddie Hansen's Avatar
if no soluion....
Richard i could give you the measurements of my old one tonight after work if it helps..
Old Aug 13, 2012 | 07:25 AM
car guy
I think I am good. Thanks for the offer.
gmiles
Jun 11, 2015 02:42 PM
Oldracerjones
Feb 1, 2014 06:05 PM
joynerz
Jul 25, 2012 07:34 AM
gearheads78
Mar 19, 2012 07:42 AM
1k442
Mar 3, 2010 08:03 AM
