Is this a "O" posi carrier
Old Jun 13, 2012 | 09:03 PM
warrior71's Avatar
Warrior
Im looking at a carrier to buy it has 588 on the bottom but on top there no 588 to match but there is a BP cast and 1 stamped. It dose have the s spring. Is this a o Type carrier I know they sometimes didn't stamp the top
Thanks Scott
Old Jun 13, 2012 | 09:27 PM
I don't think this is an O carrier. IIRC the O axle was a 12 bolt and this is clearly a 10 bolt.
I'd have to go look, but I think it is remarkably similar to my Series 2 posi for my 10 bolt.
Monzaz or 507OLDS can tell you for sure. They both build and sell differentials.
Monzaz is "Jim Mitschke" https://classicoldsmobile.com/forums...o=newpm&u=1632
507OLDS is 'Brian Trick" https://classicoldsmobile.com/forums...=newpm&u=25006
Old Jun 14, 2012 | 02:20 AM
jensenracing77's Avatar
Allan, i think it is O type. the O type has a 10 bolt ring gear and a 12 bolt cover on the axle. one of the other guys will be able to give better details.
Old Jun 14, 2012 | 04:25 AM
507OLDS's Avatar
That is a posi unit for 12-bolt O-axle.It is 28-spline,and correct for the original GM 3:42-up gears.
Old Jun 14, 2012 | 08:29 AM
warrior71's Avatar
Warrior
Ring and pinion
Thanks so much I bought it! Now my next question is I like to buy a ring and pinion for it. I like to put a 3.42 what manufacture brand will fit it.
Scott
Old Jun 14, 2012 | 08:51 AM
70w31f85's Avatar
Warrior, I dont think anyone cuts a ring and pinion for the 588 carrier. You have to use factory gears (3:42-5:00) for this carrier. If you could find a 671 carrier you could get a ring and pinion from Richmond Gear.
Old Jun 14, 2012 | 09:31 AM
507OLDS's Avatar
You can install the new Richmond gears on the 588 and 672 carriers,but you will need to mill .100" off the backside.I have done this numerous times without any issues.
Old Jun 14, 2012 | 12:21 PM
You're right; Brian confirmed that ^^^. I just looked at mine and the numbers on the carrier are 410408N, should be a 10 bolt carrier for 72.
Old Jun 14, 2012 | 02:49 PM
warrior71's Avatar
Warrior
Now my next question is which I should had ask what year is this for? Im going to use it for 68 442 and I know they used it from 67-70 and 71 was a different animal that cant be used for 67-70.
Old Jun 15, 2012 | 06:57 AM
507OLDS's Avatar
The 588 carrier came in the 67-70 12-bolt O-axles,so yes,it is correct for your 68.
Old Jun 15, 2012 | 07:34 AM
VikingBlue's Avatar
must be nice Brian to be the recognized guru about something.
No one ever asks me about anything except how I managed to let clover-weed take over every square inch of my property.
Old Jun 15, 2012 | 11:10 AM
507OLDS's Avatar
I didn't learn it or anything else overnight.
As for your clover problem,I have plenty of that too.I gotta treat it this weekend.It's the worst I have ever had it.I think it has a lot to due with the mild winter,and no freezing.More bugs,more spiders,crazy weeds,and plenty of everything else.
Old Jun 15, 2012 | 12:41 PM
Hmmm, I got a can of Killex (2-4-D) concentrate but the problem is getting it to you. You must know some farmers you can still get that stuff from?
Old Jun 22, 2012 | 10:18 PM
warrior71's Avatar
Warrior
Ok got my posi today from Cali!! Very clean unit and the funny thing is that he didn't know what he had. I got it for $85 plus shipping!
So here my next question the ring is a 3.42 which I wanted but were to find the pinion? Any suggestions guys?
Thanks for all the help and advice!
Scott
Old Jun 23, 2012 | 08:06 AM
oldsmobiledave's Avatar
Fyi
Scott
You will need a new ring & pinion set. The crown gear without the pinion will be useless as it is patterned to the pinion gear that is missing in action.
70vista
Apr 24, 2016 06:59 PM
aliensatemybuick
Jan 12, 2009 09:25 AM
4fortwo
Nov 22, 2008 10:02 AM
