TH350 Trans cooler thread size on case
Old October 22nd, 2021, 06:00 AM
1971 Supreme's Avatar
Hello All,
Just had a TH350 rebuilt, rebuilder saying there was no cooler fittings installed, eventhough there was fittings there with the 5/16 inverted flare ends. From what Ive found the casting ports should be 1/4-18NPSM. I have 1/4-18NPSM to -6 and they will only screw in approx. 3 threads. Trans shop is saying it requires 1/4 NPT thread. I don't want to crack the case and they are unwilling to install them either. Trans is going into a 71 Cutlass Supreme, trans came out of a mid 70's firebird. I'm hoping they just buggered up the threads, but before I run run a tap into them to try an clean them up, wanted to check first.
Thanks in advance for any help or advise on this
Brian
1971 Supreme is offline
Old October 22nd, 2021, 04:11 PM
I don’t know the actual thread size, but they aren’t tapered pipe thread. They use a sealing washer between the fitting and the case.
Even though it’s not right, countless people thread tapered pipe threads into the case. As long as you don’t get crazy with tightening them, you could go that route.
It should be pretty easy to find the correct fittings.
matt69olds is offline
Old October 22nd, 2021, 05:06 PM
Full-time Taxpayer
Qwik71442's Avatar
https://www.ebay.com/itm/260053255002
https://www.ebay.com/itm/274948279055
Qwik71442 is offline
442craig
April 13th, 2021 07:52 PM
76olds
January 9th, 2015 02:48 PM
coppercutlass
August 4th, 2013 07:21 PM
kjr442
January 10th, 2011 06:05 PM
Quick Reply: TH350 Trans cooler thread size on case
