70 Cutlass - TH350 Pan gasket R&R Cross member removed?
Old May 15th, 2016, 04:51 AM
Del70's Avatar
70 Cutlass - TH350 Pan gasket R&R Do you need to remove Cross member?
Do you need to loosen/shift the cross member over to remove the pan. I think I can get the two bolts out along the front, just want to be sure once I remove all bolts, that the pan can drop/clear the filter with the cross member in place...
thanks
Del70 is offline
Old May 15th, 2016, 11:03 AM
The pan on my 70 and 71 would come off without loosening the cross member, but it was a bit tight. I typically first let the front of the pan drop (the rear lip gets trapped by the crossmember when it tips) and dump fluid, then work the rear of the pan out.
Fun71 is offline
Old May 16th, 2016, 03:46 AM
Del70's Avatar
thank you. I assumed it can be done, just wanted check -
Del70 is offline
ddd777
May 15th, 2016 05:55 PM
WTony
April 22nd, 2015 11:27 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
scubastever
May 6th, 2010 08:51 PM
Quick Reply: 70 Cutlass - TH350 Pan gasket R&R Cross member removed?
