What parts for 200 4R?
Old February 2nd, 2017, 12:39 PM
edzolz's Avatar
I'm putting a 200 4R behind a mild 330. 9.0 compression, mild cam, #4 stock heads, shorty headers. Edelbrock OL4B with a Q-jet.
Do I need to go with performance parts or will stock rebuild be OK. Car is a 46 Ford street rod, 3:73 gears, maybe 3800 lbs. No racing, just cruising. Trans is originally out of a 85 Caprice.
edzolz is offline
Old February 2nd, 2017, 03:29 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I would add something like the big Transgo kit, bottom feed filter, either 700R4 or 4L60E filter, CK sells one with a spacer for the stock pan and relocation of the switch so it doesn't short on the filter. This.http://www.ckperformance.com/View/HI...R-AND-SUMP-KIT Add a hardened stator, pink 700R4 pump slide spring along with quality frictions should last a long time. A base a converter at whatever stall you want should work. The Transgo kit is not harsh. Under light throttle, very mild and just firm, full throttle. Honestly the most noticeable shift is when it downshifts to first, a slight clunk.
olds 307 and 403 is offline
Old February 2nd, 2017, 04:23 PM
Thebaby's Avatar
I put a High Performance Billet Servo .500 Boost Valve Hardened Stator Support ,10 vane pump 200-4R Superior Shift Reprogramming Kit and a 2600 stall . Most of the parts I got from Oregon performance transmission .I had about 700 bucks in the hole deal and my 68 does about 23 mpg
Thebaby is offline
Old February 2nd, 2017, 07:52 PM
I had one of the good for 500 HPOregon Performance 2600 stall converters come apart inside at the track with slicks, acted like a rubber band. On the street it was good, flashed at 2400 behind my very mild 403 for a couple of years.
Old February 3rd, 2017, 01:51 AM
If all your planning to do is cruise, if the trans is in good condition it will live behind a mild 330 just fine. If you plan to beat on it, install a TransGo shift kit. The important part is getting the TV cable adjusted right. Close enough wont work, it has to be right.
matt69olds is offline
Old February 3rd, 2017, 06:28 AM
edzolz's Avatar
It is now a moot point, I found a 200 4R from a crashed 84 Hurst that has only 500 miles on a performance rebuild (receipts in hand). Complete with stock converter, TV cable, brackets, the whole works for $200.
edzolz is offline
Old February 3rd, 2017, 09:47 AM
ART T's Avatar
Let us know how it works out. I am getting ready to put one behind a stock 330 with Fitech fuel injection.
ART T is offline
Old February 18th, 2017, 11:20 AM
TexasT's Avatar
Who assembled it? What did they claim to put in it? Sounds like a good deal if the vb and gov are the Hurst/Olds pieces.
I am in S. Arlington, we are practically neighbors.
TexasT is offline
bobsolds62
May 12th, 2016 04:30 AM
halfmoontrail
July 13th, 2011 11:43 AM
71 Cutlass
18
September 20th, 2010 11:10 AM
Olds64
January 29th, 2008 06:17 AM
J-(Chicago)
Drivetrain/Differentials
December 11th, 2007 07:08 PM
Quick Reply: What parts for 200 4R?
