powerglide?
Old February 12th, 2009, 11:10 AM
69 cutlass owner
amrcnmscle's Avatar
powerglide?
how can you tell if the transmission you have is a powerglide and how can you tell if the transmission you have originally came with the car???????
thanks
amrcnmscle is offline
Old February 12th, 2009, 03:07 PM
thanks
Is this an Olds or something else? If it's an Olds, I can tell you right now that it is NOT a Powerglide. The two-speed trans used by Olds for 64-67 was a Super Turbine 300 (AKA Jetaway). Contrary to popular belief it is completely different from a Powerglide and no parts interchange.
As for trans ID, try this:
http://www.autotran.us/gmABpg26.htm
Note that is says "the name POWERGLIDE is embossed on the case" for Powerglide transmissions.
joe_padavano is online now
Old April 12th, 2009, 05:39 PM
monzaspyder79's Avatar
So, A Torque converter of powerglide ('67 Camaro), Doesnīt fit in a Jetaway tranny?
monzaspyder79 is offline
Old April 12th, 2009, 06:38 PM
Jetaway transmissions usually came with a switch-pitch torque converter. Powerglides did not. They are not interchangeable.
Old April 13th, 2009, 11:20 AM
d2_willys's Avatar
Joe: I believe BOP used the ST-300 in 68, 69, but had no switch pitch feature. Pontiac never used the switch pitch in their ST-300's aka Tempestorque. But if you take it a little farther Pontiac borrowed the Corvair Powerglide for the 61-63 Tempests, and of course called the Tempestorque. As you pointed out, Chevy invested in putting the name POWERGLIDE on aluminum cased SLIDES. The cast iron SLIDES had merely a pressed on plastic button with the word POWERGLIDE and it's associated patent #s.
d2_willys is offline
Old April 13th, 2009, 12:31 PM
You are correct. Good catch. The 68-69 Jetaway is not switch pitch and a PG converter should work. By the way, the use of the PG converter in TH350 and TH400 transmissions is an old low-buck way to increase stall speed.
Old April 21st, 2009, 05:36 PM
Hi! So, what tranny is in this picture? and it has switch-pitch? Switch pitch is when the 2 wires (black and yellow) ?
This tranny corresponds with my Cutlass? itīs the original tranny?
Thanks !!!!
Old April 21st, 2009, 05:46 PM
Registered Luser
ent72olds's Avatar
I'm no tranny expert, but what year cutlass do you have? Those wires may be the electronic kickdown....therefore a jetaway.....
ent72olds is offline
Old April 21st, 2009, 07:01 PM
d2_willys's Avatar
Looks to be a 1967 Jetaway 2 speed, with switch pitch.
Old April 22nd, 2009, 12:02 PM
I have got a 67 Cutlass Supreme.
Old July 21st, 2009, 03:23 PM
I need you again!
I need to buy new (or remanufactured) Torque converter for my girl friend 67 Olds Cutlass Jetaway transmission. But I donīt know this torque converter will works in my 67 Jetaway:
http://cgi.ebay.com/ebaymotors/GM-ST...Q5fAccessories
If my Jetaway is with Switch-pitch...Do you think this torque converter fits and works in my Jetaway? This Torque converter is for switch-pitch?
"BPO, 8 Cyl Fixed Pitch Stator, Kickdown Solenoid on VB"
Thanks again!
Old July 21st, 2009, 03:46 PM
380 Racer's Avatar
Wasn't it a Vega converter they used to get the cheap stall? I think they were TH350 converters. Over on ROP (I think) someone had an Olds bolt pattern powerglide out of one year with no TH350 available. I know of a couple guys racing with them.
380 Racer is offline
Old July 21st, 2009, 06:42 PM
It is, as proven by the two wires going into the side of your trans (one for kickdown, one for the converter).
Sorry, but no. The fixed pitch stator is not the switch pitch stator.
Old July 22nd, 2009, 02:31 PM
Thank you for your help, Joe.
I am very grateful.
Old January 16th, 2010, 11:24 AM
Hi guys! Happy 2010!
Well, I have no more problems with the converter, because the BIG problem is the trans... Here, in Spain, can't repair my jetaway, itīs totally cracked, including the housing.
I want to buy some trans in the USA. I'm thinking in a th 400, but I continue thinking about in a 2 speed trans. I don't know what to do and in Internet I donīt find specialist sellers webs in 2 speeds trans. Can I to install a Chevy Powerglide? Itīs possible with an adapter?
What is better/cheap, an th 400 or a 2 speed?
If I install a th 400, what about the column shift? I need to install a center console shifter?
I guess that many people enter this forum asking the same questions that I, but for me itīs too hard to find and understand all that answer that I need to know, so sorry and thanks for the answers!
Old February 12th, 2010, 11:31 AM
d2_willys's Avatar
A TH350 will work just fine for your car, just get one with the BOP pattern. You will need to make a kickdown cable installation as TH350'S did not use electric kickdown switch. They also were fixed pitch converters, so no need for the wiring you have. I believe the transmission is the same length as the Jetaway 2-speed. The 350's should be abundant anywhere.
Old February 12th, 2010, 12:29 PM
X2. The TH350 swap for a Jetaway is very easy and very common.
amrcnmscle
20
December 3rd, 2020 10:55 AM
Kyle's 77 Cutlass
December 2nd, 2014 04:01 AM
cutty
May 16th, 2010 12:31 PM
tlucas07
March 23rd, 2009 11:40 AM
scubastever
January 16th, 2009 09:09 AM
Quick Reply: powerglide?
