Gear oil?
Old July 5th, 2014, 01:50 PM
foo
foo's Avatar
Gear oil?
What gear oil should i use for m20 and how much do i fill it?
foo is offline
Old July 5th, 2014, 02:41 PM
Regular SAE 80W90 gear oil is fine. 70W140 synthetic is overkill, but also fine.
You can look up the quantity on the interwebs.
MDchanic is offline
Old July 19th, 2014, 06:50 AM
Rocketguy's Avatar
I just put new fork seals in mine and the man that sold them to me said that he did not recommend using synthetic oil in the Muncie because they tend to leak with it.
Has anyone experienced this?
And what about the 75-90 synthetic? For some reason it is much cheaper than the 70W140
Rocketguy is offline
Old July 19th, 2014, 07:16 AM
I'd use the 80/90 wt non synthetic. Fill to 1/2 inch below the fill plug hole located about 1/2 way up the side of the case. I usually push my finger through the hole and fill until I can touch the oil by bending the first digit of my finger.
oldcutlass is online now
Old July 19th, 2014, 10:39 AM
ELY442's Avatar
X2, I do the same thing with the rear end gears.
ELY442 is offline
Old July 19th, 2014, 03:31 PM
442Harv's Avatar
Also make sure it is GL4, not GL5.
442Harv is offline
Old July 20th, 2014, 10:32 AM
dc2x4drvr's Avatar
X2
Muncie's don't like synthetic gear oil.
dc2x4drvr is offline
Old August 14th, 2014, 06:48 PM
hilbily's Avatar
I had a bunch of Red Line synthetic gear oil at work so I figured what the heck and filled up my Muncie. Came out to some puddles under the car and got to checking it out and the oil was bleeding right thru the porous casting. No matter the wt of synthetic it always seems light. Put good old 75-90 back in it never had another leak.
hilbily is offline
drjr56
September 9th, 2012 08:05 PM
jerseyjoe
November 11th, 2011 04:07 PM
dc2x4drvr
November 2nd, 2010 07:21 AM
STLCRZY
Drivetrain/Differentials
September 4th, 2007 10:26 PM
Quick Reply: Gear oil?
