Converter spacer washers
Old October 6th, 2016, 04:56 PM
CJG
CJG's Avatar
Ok. Using the transdapt kit to bolt my 438 to a Chevy trans. The kit came with 2 spacer washers for the converter to Flexplate bolts. Its not enough. I have to pull converter completely into the crank boss to come right. I've read some reviews where some people have said they needed 3 washers on each bolt. My question is would it matter if the 3 rd washer was a lock washer? Its all I have around that's the correct diameter/thickness. I don't see why it would hurt anything, and maybe even help keep things tight.
CJG is offline
Old October 7th, 2016, 06:40 AM
CJG
CJG's Avatar
Nevermind, found some correct washers. All is good I think!
CJG is offline
Old October 7th, 2016, 09:09 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
When used a bell housing adapter and aftermarket converters, that need the gap filled, regular washers work fine.
olds 307 and 403 is offline
Old October 23rd, 2016, 12:31 PM
transman74's Avatar
The proper way is to have a converter built to take care of the bell housing difference.
We built a ton of converters for race cars that used a mid-plate. All we asked was the thickness of the plate and built the converter accordingly. This procedure was also done when someone had a transmission they were mounting to a different brand engine.
IMHO washers are a poor way to go.
Do it right - once
transman74 is offline
GINCSC
December 19th, 2015 01:49 PM
starfire
August 26th, 2011 01:08 PM
matt69olds
August 4th, 2010 10:23 AM
Ddbord
May 28th, 2010 07:47 PM
nelsontj
May 5th, 2010 05:30 AM
Quick Reply: Converter spacer washers
