chevy th400 trans same as olds th400
Old November 10th, 2010, 08:51 PM
ls442's Avatar
will a th400 from a older corvette work with a71 olds455 motor a have a th350 in it now the car is a 67 cutlass convt
ls442 is offline
Old November 10th, 2010, 09:12 PM
olds425's Avatar
You can make it work with an adapter, the bellhousing is a different pattern. It also may be a short tail shaft trans and I think the yoke is different between the TH350 and the TH400. Someone else probably knows more than I do and should chime in soon.
olds425 is offline
Old November 10th, 2010, 10:56 PM
Redog's Avatar
The 400 spline shaft is thicker than the 350 shaft, so you will need a different yoke is swapping between the 2 different trannies.
The 400 also came in 3 differnet tail housings. 4 inch, 9 inch and 12 or 13 inch (don't remember exactly) Also the speedo gears are inside the tranny housing, not the tail housing like the 350.
Yes adapter plates work well, but it sucks for us Olds guys. A BOP tranny to a Chevy plate is around $50, but a Chevy tranny to a BOP engine is closer to $100
Redog is offline
Old November 11th, 2010, 04:33 AM
Rickman48's Avatar
I've used the BOP to Chevy plate behind a BB without incident.
Seems silly to have 2 prices as the difference is a couple of tapped holes!
Rickman48 is offline
Old November 11th, 2010, 05:59 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
http://www.afabmetalworks.net/Fabricated%20Parts.html
J-(Chicago) is offline
Old November 11th, 2010, 10:45 PM
Redog's Avatar
I agree
Redog is offline
nj_cutlass72
January 2nd, 2013 09:19 AM
hoppers69
April 30th, 2012 06:55 PM
charlierogers
March 10th, 2012 06:31 AM
jeffreyalman
June 6th, 2009 06:28 PM
Super88inWilm
March 30th, 2006 04:32 AM
Quick Reply: chevy th400 trans same as olds th400
