55 Olds - Machining Crank for Pilot Bushing
Old July 14th, 2011, 09:54 AM
Collector of Stray 55's
Olds Dad's Avatar
I have a lead on a 55 with an original 3 speed on the column - car has a bad engine but is otherwise very good - I have a beautiful running 324 but it's mated to a Hydra-Matic...can the necessary machine work for the pilot bushing / bearing be done without having to remove the crank - engine is out of the car and bolted to a wheeled skid - could be easily transported to a shop.
If I can have this work done without having to tear the engine down then it's worth me getting the car - If I'll need to tear apart (and subsequently rebuild) the engine I have then it's not worth it to me
Olds Dad is offline
Old July 20th, 2011, 10:52 AM
d2_willys's Avatar
You might not have to do anything to the crank. The Olds rockets with dual range hydramatic (not Jetaway) have a pilot bushing already, as the hydramatic input shaft centers in the crank pilot bushing. Now if the 3 speed and hydramatic input shaft has the same diameter (where the shaft goes into pilot bushing) then you are in business! If not, you could get the right bushing and just use a pilot bushing remover. No crank work!!!
Bet you never thought it would be this easy!
d2_willys is offline
Old July 20th, 2011, 04:57 PM
Olds Dad's Avatar
Awesome...hope you are right..thanks
Olds Dad is offline
4-Speed
Drivetrain/Differentials
April 6th, 2014 03:20 PM
citcapp
48
March 30th, 2014 03:40 AM
4-Speed
February 18th, 2014 04:50 PM
lugnutx2
October 23rd, 2012 06:52 AM
ROBZ442
March 2nd, 2011 08:13 AM
Quick Reply: 55 Olds - Machining Crank for Pilot Bushing
