1967 Cutlass Supreme Clutch Pedal
Old July 13th, 2023, 11:48 AM
DLaz70OLDS98's Avatar
I am in the process of converting from an automatic to manual transmission. I am installing a TKX 5 speed that I got from Silver Sport. I have an issue with the clutch/brake pedal assembly they sent. When you push the clutch all the way down it hits the large fuse for the flashers.
I am questiong if I was sent the wrong set of pedals. When I got my shipment from them this bag was previously opened. I was hoping that someone who has a 67 manual trans could take some pictures of thier pedals and clearance to the fuse. Or if somebody might have any additional insight on this.
Thanks all!
Drew
DLaz70OLDS98 is offline
Old July 13th, 2023, 11:55 AM
fleming442's Avatar
No, it's a thing; mine did it, too. The ghetto fix is to extend it out of fuse box with wire and spade connectors. Otherwise, call the manufacturer to see what they say.
fleming442 is offline
Old July 13th, 2023, 12:05 PM
I appreciate the feedback and suggestion. Bummer that it has to be Jerry-Rigger. So it sounds like it's a reproduction part issue?
Old July 13th, 2023, 12:19 PM
fleming442's Avatar
1st thing to try would be getting a smaller flasher, like the round ones.
Old July 13th, 2023, 12:47 PM
You're not using reproduction parts; you're using aftermarket performance parts made for many applications. The 1967 flasher fuse was not considered in its design. Minor, sometimes major, fitment is required when putting a non-original part in the car. Now, if you had put a 67's clutch pedal in it, that would be different.
Koda is online now
Old July 13th, 2023, 12:53 PM
HA! I already tried and that guy sits a wee higher!
Old July 13th, 2023, 12:55 PM
Apologies, misuse of terminology.
Old July 13th, 2023, 09:19 PM
That style clutch pedal is for the 1968-72 cars, which is why you have a problem.
joe_padavano is offline
Old July 14th, 2023, 05:28 AM
Joe, thanks for the feedback. So my question now, did they mess up and send me the 68-72 version or is this just what they are passing off as an aftermarket part?
Old July 14th, 2023, 05:31 AM
I suspect the latter, but I have no idea what they were thinking
Old July 14th, 2023, 06:42 AM
Old(s)GuysRule
67OAI's Avatar
Used assemblies come up as available every now and then. I just recently removed the pedal assembly from a '67 442 body which I acquired as a donor. Shoot me a PM if you are interested in purchasing it. I'm at Exit 7, I-95 in Georgia.
67OAI is offline
Old July 26th, 2023, 07:29 AM
I ended up ordering another brake/clutch assembly from the Parts Place that states it is for a 1967 Cutlass. Well, as no big surprise, the same issue existed. I ended up modifying the pedal that Silver Sport sent and it clears the fuse and operates as it should.
Old July 26th, 2023, 02:09 PM
FYI, all of those aftermarket pedals likely come from the same factory in China, so don't expect them to get it right. Just buy a good used original.
woodeye3
June 27th, 2023 06:29 AM
mclark68442
July 27th, 2022 01:48 PM
ThatsMe
July 22nd, 2022 01:50 PM
442gs
June 30th, 2020 07:31 AM
higgenslake
January 31st, 2013 09:01 AM
Quick Reply: 1967 Cutlass Supreme Clutch Pedal
