Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Motor mount application list
Old January 9th, 2015, 09:39 AM
  #81
young olds's Avatar
it was a 6 cylinder car which is actually irrelevant because i bought it without anything on the frame.
young olds is offline
Old January 30th, 2015, 12:12 PM
  #82
naphtali5725's Avatar
Actually, the frame-side mounts are bolted to the frame, not riveted.
This is why I suggested the Chevy clamshell mounts. These put the rubber on the frame side, and since the rubber does deteriorate, replacements are readily available. Anchor P/N 2387 are used on the 403 Trans Am as well as on a bazillion Chevy applications,
The 403 block-side brackets to mate with these are also pretty readily available. People who are pulling the 403s out of their Pontiacs sell them all the time on ebay, and reproductions are also available.
joe,
this is a two piece correct? is the straight bar required to be used? or can just the piece that cross bolts to the frame mount be used?
naphtali5725 is offline
Old January 30th, 2015, 12:17 PM
  #83
Originally Posted by naphtali5725
joe,
Yes and yes. The straight bar bolts to the three motor mount bolt holes in the Olds block and has two studs that the U-shaped bracket bolts to. There's no other way to attache the U-bracket to the block.
joe_padavano is offline
Old January 30th, 2015, 12:32 PM
  #84
Thanks joe!
Old January 30th, 2015, 04:39 PM
  #85
one more thing, are those mounts available other than on ebay/junk yard?
Old January 31st, 2015, 04:58 AM
  #86
Great thread! Thanks to Joe. I know this has been brought up before. But I can't find good quality mounts. My 71 Cutlass 350 had sagged so much the oil pan hit on the crossmember. My 70 Vista 350 had a small aftermarket flex fan on it when I bought it and when I attempted to put the original factory type clutch fan back on it, I found the mounts had sagged. I had to replace them to get the fan on. Now after 5 years or so I can tell the mounts in the Cutlass have started to sag again. Also the motor mounts on my 65 Coronet big block had sagged causing the headers to hit on the pitman arm. I finally replaced those with Schumacher polyurethane mounts and it raised the engine 3/4 inch. But I hate those! Car shakes like it has solid mounts! Anyone know of higher quality mount available?
Greg Rogers is offline
Old January 31st, 2015, 11:23 AM
  #87
I've seen them offered by Firebird/Trans Am specialty houses, but I don't know if those are used or repros.
Old January 31st, 2015, 11:25 AM
  #88
Unfortunately there are no polyurethane mounts for Olds motors that I am aware of. Supercars sells very nice Olds mounts, though I have no first-hand experience with them. Other Olds vendors sell reboxed Anchor/Pioneer Chinesium mounts at far higher prices than RockAuto.
Old January 31st, 2015, 12:00 PM
  #89
thanks joe! you wouldn't happen to have a set for sale would you? LOL
Old January 31st, 2015, 02:13 PM
  #90
Sorry, I've got one set that's on the shelf waiting for some mythical future project...
Old March 4th, 2015, 05:23 AM
  #91
thanks Joe,
i got the flat bar mounts from a member, and i found a set of the ones that bolt to the anchor 2387's on a firebird central site...
Old July 19th, 2015, 09:00 PM
  #92
real57vetteguy's Avatar
1964-1968 frame mounts (all) - use P/N 2261 motor mounts
1969-1972 SBO frame mounts - use P/N 2261 motor mounts
1969-1972 BBO frame mounts - use P/N 2328 motor mounts
1973-1988 frame mounts (all) - use P/N 2328 motor mounts
This is good info, my understanding is that PN 2261 is roughly 1-5/8 from mount engine mount hole to center of frame mount hole, PN 2328 is 2-1/2, you can also use PN 2286 which is a ford/mercury part number and it measures right under 2 inches. I actually ran that on my BBO for the last year. So it's in between the Olds mounts but still fits.
I'm getting ready to change to the taller mount so I have a spare set that I would be happy to send you Joe for verication just to put into the data bank of what fits and what will work I can see where this might be beneficial for some people doing engine swaps
real57vetteguy is offline
Old July 14th, 2016, 07:27 AM
  #93
Cj72olds's Avatar
Thanks Joe
Another question then.
Do I use the 2261 motor mounts since the motor is from 1968
of the 2328 motor mounts for the 1972 frame? With matching frame mounts of course.
Curt
Cj72olds is offline
Old July 14th, 2016, 07:41 AM
  #94
Originally Posted by Cj72olds
Thanks Joe
Curt
The block doesn't matter; all Olds blocks have the same motor mount bolt holes. Just get the motor mounts that match the frame mounts.
Old July 14th, 2016, 07:45 AM
  #95
Cj72olds's Avatar
thanks
Cj72olds is offline
Old December 13th, 2018, 04:52 PM
  #96
Holy Snot Rockets. Exactly the information I was searching for. Thank you, Joe.
Vintage Chief is offline
Old December 19th, 2018, 07:32 AM
  #97
oldaman's Avatar
455 4spd
thank you for all of the info and sharing your knowledge with everyone
oldaman is offline
Old March 3rd, 2019, 05:49 PM
  #98
Schurkey's Avatar
Anyone have a source for the single front, and double rear (transmission) rubber mount cushions for Toronado?
I re-used the mounts that came with the car, but I expect they're original 1966 items. They're due for replacement.
Schurkey is offline
Old March 4th, 2019, 06:24 AM
  #99
Unfortunately, no one makes replacement motor mounts for these cars (though everyone incorrectly lists the Delta 88 mounts for the Toro). Your only options are to find good used ones or to have your originals re-vulcanized by Steele Rubber.
Old January 31st, 2021, 06:24 PM
  #100
I wanted to add this here so it's documented in the motor mount sticky. Here are a 2261 and 2328 side-by-side with the correct frame pad for each. I've tried to match scale and line up some reference points. Unfortunately, the photos are not quite at the same angle, so there's a little distortion. Note that relative to the bolts in the frame (which are the same in both cases), the motor mount bolt holes in the block are in exactly the same place. Also note how the 2328 wraps down under the oil pan rail and is closer to the pan than the 2261. The lesson there is that if you have an aftermarket pan, you might want to use 2261 mounts and matching frame pads for a little extra clearance. On the other hand, 2328 mounts provide a little more room for headers.
Old March 1st, 2021, 07:06 AM
  #101
John Farm's Avatar
Thank you. Very good string
John Farm is offline
Old August 16th, 2021, 02:00 PM
  #102
wpgjetfan's Avatar
Previous 403 villian where a 455 should call home!
Understand the A bodies have the bolt going down and are unique... do those bolt down through the frame? My W30 had a "403" swap (apparently
- a rescued parts car...)
I assume the current incorrect mount covers the needed holes? Every other car I have is a 350 or a parts car. A pic of what it should be would be really helpful (installed view)... thanks. Brian
wpgjetfan is offline
Old August 16th, 2021, 02:09 PM
  #103
I'm not sure what you mean by "bolt going down". The only Olds motor mounts with a threaded stud that goes through the frame are the ones for the 1964 and 1965-70 full size cars (photo below). The mounts in the photo you posted are correct for the 2328 motor mounts used on the 1969-up BBO A-body cars and all 1973-76 A-body cars with any Olds motor.
This is the 2262/2263 style mount for the 65-70 full size cars only.
Old August 16th, 2021, 02:13 PM
  #104
wpgjetfan's Avatar
On Summit is shows these for the 70 Olds 442 W30 and other websites so that is my confusion! If these are incorrect... that is great news. I am good to go then. Trying to get it right and motor mounts I have never got a straight goods answer. Thanks!
Old August 16th, 2021, 02:16 PM
  #105
Once again, nearly EVERY catalog you look at lists Olds motor mounts incorrectly. Scroll up and read the first post on the first page in this thread.
Old August 16th, 2021, 02:21 PM
  #106
wpgjetfan's Avatar
The 2328 like ones are what I have been pulling off my big block parts engines and was so hoping that is correct. I have hesitated so many times to order new for my W30 resto as I was never sure. Yep, you list is clear but of course is contradicted by many websites. I'll take your list as the gospel. The bolt downward just confused the hell outta me. Take it easy!
Old March 26th, 2022, 08:03 AM
  #107
71 Cutlass Supreme Conv
uncle dave's Avatar
Hello to all, new to Olds. Question I have that I haven't seen yet is which 2 bolt holes on the block do you use. Doing a resto mod on a 71 Cutlass conv. that had a 350 in it but I'm swapping in a 455. Car came with no engine and 455 came with no mounts attached to it. Just trying to avoid redoing it if I choose the wrong location from the beginning.
Appreciate any help given.
uncle dave is offline
Old March 26th, 2022, 09:17 AM
  #108
Welcome. The A-body cars use the rear two of the three motor mount bolt holes in the side of the block. And hopefully you didn't buy "455" motor mounts. If your Cutlass has the original frame pads get Anchor 2261 mounts.
Old March 27th, 2022, 05:45 AM
  #109
uncle dave's Avatar
Thanks for the quick response. No, I actually had the 2328 mounts until reading all this. I ordered the 2261mounts now. Thankfully they were both rather cheap.
Old March 27th, 2022, 06:28 AM
  #110
Be sure your chassis has the original frame pads. Scroll up to the first page in this thread for photos.
ergot71
February 18th, 2020 05:38 AM
edzolz
August 21st, 2017 08:44 AM
Se7enty5
May 12th, 2015 08:48 AM
Beob
April 5th, 2011 10:14 AM
procharged70cutlass
December 21st, 2009 09:21 AM
Quick Reply: Motor mount application list
