Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
67 442
Old January 17th, 2014, 08:53 AM
Thomas Simcich's Avatar
67 442
Could use some help with casting numbers to verify a 1967 442 engine. What should the numbers be? Car was built first week of January. Thanks in advance for any help. Is there a casting date for the heads? If so where are they located?
Thomas Simcich is offline
Old January 17th, 2014, 09:11 AM
Octania's Avatar
E block
C heads
E intake manifold. 2027xxx carb, I forget, '156 or similar.
X LH exhaust manifold
W RH ""
OG auto trans, WOG ?? for W30 ?
Octania is offline
Old January 17th, 2014, 10:08 AM
One of the heads (front of the passenger side head or rear of the driver's side head if they were swapped during a valve jobe) will have an engine unit number that begins with the letter "V":
Of course, that just proves that one head is from a 442. The C heads were used on all 1967-69 BBOs (except W-30s and most H/Os), and the 400 block was used in the Turnpike Cruiser and VC.
Casting date codes should typically be within 30 days before the build date of the car; there have been some instances of casting dates up to 90 days before, but that's less likely. Obviously no casting dates can be AFTER the build date of the car.
joe_padavano is offline
Old January 17th, 2014, 10:27 AM
steverw's Avatar
On the carb number theres a 2027156, and 2027157 one is for an A.I.R. car the other is not. I dont know what the internal differences are.
steverw is offline
Old January 18th, 2014, 07:29 AM
I seem to remember something about casting numbers on the engine being Julian dates. Can someone explain the Julian date? Where can I find the casting date of the block, intake manifold, exhaust manifolds, etc?
Old January 18th, 2014, 07:41 AM
66400's Avatar
Julian date, numbers 1-365 or 366 for leap years. Example Feb 2 = 33 or Aug 6 = 218 or Dec 31 = 365.
Block casting date located at back of block by distributor, will be a number between 1 and 365.
Intake forward of carb, exhaust manifolds on the side.
Henry
66400 is offline
Old February 5th, 2014, 08:57 AM
Is there a casting date for the heads? If so where is it located on the heads?
Old February 5th, 2014, 09:26 AM
66400's Avatar
It will be towards the rear of the head on the driver's side of the cars, towards the front of the car on the passenger side. inline with the heads ID cast #'s.
Henry
66400 is offline
Old March 26th, 2016, 07:22 PM
67442nut's Avatar
I believe that carb number is 7027156, not 2027156.
67442nut is offline
Old March 26th, 2016, 08:59 PM
lemoldsnut's Avatar
Intake casting should be 390390
lemoldsnut is offline
