Rear Shocks
Old September 9th, 2016, 05:53 AM
NOVICE car nut
oldsguybry's Avatar
Rear Shocks
I'm going to have to get some new shocks because the car currently has some real old air shocks and they don't hold air in them very well anymore , and they look quite old . Do you think these would be a decent replacement ?
I kind of want the rear up a bit , that's why I was looking at these .
oldsguybry is offline
Old September 9th, 2016, 06:03 AM
If the car does not sit at the level you want without the airshocks aired up then I suggest a new pair of springs. The upper shock perches are not meant to support the cars weight. The coil assists are a good combo with new springs, however the ride will be very stiff.
oldcutlass is online now
Old September 9th, 2016, 06:09 AM
Agreed. New springs are not expensive.
CargoCoils are probably the best, because they are a bit firmer, and maintain the ride height better with a load.
If you want it high, get station wagon springs.
If you want to go cheap, get them at the junkyard.
MDchanic is offline
Old September 9th, 2016, 10:20 AM
NOVICE car nut
oldsguybry's Avatar
Good info , thanks
Old September 9th, 2016, 12:28 PM
Hookers under Hood
76olds's Avatar
X3, I would stay away from the pic you posted " Load leveler shocks" so they are called here.
Wagon coils and shocks if you want height as Eric suggested would be the way to go.
Eric H
76olds is offline
Old September 9th, 2016, 12:36 PM
delete
droptopron's Avatar
Just for ref, Rock Auto has rear springs starting around $50 plus insulators for $3
droptopron is offline
Old September 10th, 2016, 07:19 AM
NOVICE car nut
oldsguybry's Avatar
Thanks for your input guys .
RetroRanger
February 25th, 2014 05:04 PM
71RadioflyerVista
Suspension & Handling
March 14th, 2011 11:00 PM
Noisemaker
March 13th, 2011 01:50 PM
AZ442
August 24th, 2009 07:32 AM
aristellier
December 19th, 2006 03:51 PM
Quick Reply: Rear Shocks
