First start of the car, carburetor over flooding?!
Old October 25th, 2014, 11:15 AM
Teamcamber's Avatar
Hi!
Today the first test run of the engine was done. The car has been sitting for maybe 4 years. But I havent touch the engine, more then sparkplugs, oil and som more stuff.
First run was okej, it worked as it should. We then started it a few times and everything was fine.
One hour later, when I start the engine it was going about 15sec before it dies. Next try is the same, the engine is runner for about 15sec then it dies.
Some gas was dripping around the carburetor from the air filter.
Whats my next step? Is the needle stuck or what do you think?
Hope you understand what i mean.
Teamcamber is offline
Old October 25th, 2014, 11:20 AM
Octania's Avatar
Dirt in the needle/ seat
easy fix
Octania is offline
Old October 25th, 2014, 09:21 PM
Proud Viet Nam Veteran
redoldsman's Avatar
While you are working on this please have a fire extinguisher close by. Don't ask me why I tell you that but you probably would get it right on the first guess.
redoldsman is online now
Old October 26th, 2014, 07:33 AM
Hookers under Hood
76olds's Avatar
You could try to lightly tap the top of the carb with a hammer, then start it up.
Hope this helps
Eric
76olds is offline
Old October 27th, 2014, 12:26 PM
Teamcamber's Avatar
Problem fixed, dirt in needle, thx!!
Old October 29th, 2014, 04:26 PM
jerseyjoe's Avatar
New gas does not help for sure. May want to pull the top off of the carb and clean the bowl (if you did not already).
jerseyjoe is offline
Professur
September 9th, 2014 09:10 AM
JohnnyBs68S
August 11th, 2014 06:51 PM
Dshelvy
January 5th, 2013 09:09 PM
VikingBlue
February 14th, 2011 07:34 PM
Red Delta
April 9th, 2010 08:31 PM
Quick Reply: First start of the car, carburetor over flooding?!
