Ram Rod 350
Old Jul 12, 2008 | 10:23 AM
72 Supreme's Avatar
Ram Rod 350
Does anyone know anything about these set ups like was the intake cast iron or aluminum, valve specs and cam specs,size of exhaust manifolds. Any info would be appreciated.
Doug.
Old Jul 12, 2008 | 01:50 PM
Doug.
The 68 Ram Rod 350 (and identical 69 W-31) used the same heads and cast iron intake as all other 350s in those years. The heads had the 2.000/1.625" big block valves installed. The 308 deg cam used in earlier W-30 motors was used in the 68-70 small blocks. Exhaust manifolds were the same as used on all other 350s, complete with a cap on the crossover port on the RH manifold.
Old Jul 12, 2008 | 06:28 PM
z11375ss's Avatar
Senior Moment Member
These cars came with a 3 or 4 speed only. A special harmonic dampener was also used. I have a cloned one in the section Well here it is! Located down the small block page. Take a look it's pretty cool. Mine has incorrect red fenderwells. They should be black but they came with the car and I just couldn't take em out.
71HolidayCutlass
Nov 9, 2018 06:14 PM
jaydc68
Sep 16, 2013 08:21 PM
'S'tuff1979
Sep 25, 2012 08:25 AM
'S'tuff1979
Sep 24, 2012 06:24 PM
442ric
May 30, 2011 07:27 PM
