Compressed air from oil filler tube
Old Jun 25, 2008 | 02:54 PM
  #41
54olds's Avatar
Nothing new beats an Olds
Originally Posted by Texascarnut
I really hate to say this, but with a constant light gray or bluish gray emission from the tailpipe and the results you got from the leak down, the engine needs a major rebuilding, which may require boring the cylinders. It is for certain the heads need a major rebuild and there is no reason to do that and put them back on when it appears you have one or more cylinders that are no longer true. If you haven't already you should do a compression test on all cylinders. I suspect the results of a compression test are not going to be good, unfortunately.
Actually, I did a compression test a few months ago - this is what I recorded:
Logically, A+B must equal C, but how could I get those kind of readings if the cylinders or rings were bad - wouldn't that show up as low compression? But yet, the results of the leakdown test were not good.
I tell ya, this is driving me batty!
Old Jun 25, 2008 | 07:47 PM
  #42
marcar1993's Avatar
I think "good" compression is better than 135-140 psi.
Old Jun 25, 2008 | 09:33 PM
  #43
88 coupe's Avatar
Junior Member
........ There is always a certain amount of pressure in the crankcase created by piston movement ........
Nothing to do with the road draft tube that was being discussed?
........ If you don't believe that just crawl up under a car ........
I will let that statement speak for itself.
Norm
Old Jun 25, 2008 | 09:48 PM
  #44
88 coupe's Avatar
Junior Member
Originally Posted by 54olds
Out the exhaust. It smokes light but steady when idling, and of course increases considerably when raced. The smoking seems to be about the same as idling when you're driving.
Classic definition of worn oil rings.
An engine rebuild, by a competent machine shop, might be a good choice.
Norm
Old Jun 25, 2008 | 10:16 PM
  #45
88 coupe's Avatar
Junior Member
........ It idles fine when it's cold ........
While it's still on the choke?
........ at a stoplight, the idle will run rough and drop to the point where it will stall if you don't give it some gas ........
Idle mixture/speed adjustments and/or vacuum leak.
Norm
Old Jun 25, 2008 | 10:54 PM
  #46
88 coupe's Avatar
Junior Member
Originally Posted by marcar1993
........ does effectively evacuate the crankcase at idle ........
How is it accomplished?
........ Do olds road draft tubes have a small square of sheet metal on the front ........
No. As I said, it's function relies, solely, on the placement of the tube.
........ I'd suppose it couldn't be much of a different principal.
No different than they used in the '30s, and earlier.
Norm
Old Jun 25, 2008 | 11:05 PM
  #47
88 coupe's Avatar
Junior Member
........ It is for certain the heads need a major rebuild ........
I have not seen anything to indicate a problem with the heads.
Norm
Old Jun 26, 2008 | 01:50 AM
  #48
88 coupe's Avatar
Junior Member
Actually, I did a compression test ........
Yes.
Referred to, in post number3, for anyone who might have missed it.
Was the battery fully charged? Engine at normal operating temp? All plugs removed? And the throttle valves (plates) fully open?
........ I did my compression readings, they were all between 103 and 115 ........
103 is more than 80% of 115, and 103 is above the 100 PSI minimums, as shown in the '54 Service Manual.
If all of the above conditions were not met, these numbers would have been higher.
........ Logically, A+B must equal C ........
It does, if the right values are used. In this case, the needed values are in the basics.
........, but how could I get those kind of readings if the cylinders or rings were bad ........
They show the total pressure that is built up, during that compression stroke, in that cylinder, at that time. Leaking valves, rings, gaskets, etc, can contribute to a "less than ideal" combustion environment. Unless one can identify, and evaluate. each of the variables, the test can only show the "relative" condition of the entire cylinder.
One thing to think about, is the difference in maximum pressures, during compression vs power strokes. Most blowby occurs during the power stroke. Very little during compression.
........ But yet, the results of the leakdown test were not good ........
Leakdown and compression tests are the same, only different.
They both show cylinder leakage, but the leakdown can tell the source.
........ I tell ya, this is driving me batty!
Happens when one doesn't stay focused on the basics.
Norm
Old Jun 26, 2008 | 02:08 AM
  #49
88 coupe's Avatar
Junior Member
For a "high compression" '54 Olds, as it left the factory, that would be a good guess.
Norm
Old Jun 26, 2008 | 06:41 AM
  #50
54olds's Avatar
Battery was fully charged and I let the engine run until it was nice and warmed up. The throttle plate was all the way open - the only thing I did not do is take all the spark plugs out before I did the test. Would that have made much of a difference in the readings?
Old Jun 26, 2008 | 06:43 AM
  #51
54olds's Avatar
Norm
I'm leaning towards rings as well. Does the motor have to be taken out for a ring job?
Old Jun 26, 2008 | 06:56 PM
  #52
88 coupe's Avatar
Junior Member
........ Does the motor have to be taken out for a ring job?
No.
Back in the day, it was common to "recondition" an engine, without removing it.
Whether it would be practical, in your case, would depend on its condition and your budget.
Norm
Old Jun 26, 2008 | 07:32 PM
  #53
54olds's Avatar
I plan on finishing my leakdown tests and do another compression check this weekend - I'll let you know if I find anything new then.
Old Jun 26, 2008 | 08:19 PM
  #54
88 coupe's Avatar
Junior Member
I plan on finishing my leakdown tests ........
If you are able to plug the two holes in the crankcase:
Apply air pressure to each cylinder, while listening at the carb inlet and the exhaust outlet, for the sound of escaping air.
Norm
Old Aug 7, 2008 | 01:22 AM
  #55
88 coupe's Avatar
Junior Member
Found this post, while looking for, the above, vacuum hose information.
........ I did find this curiosity hooked up to the vacuum line and dangling between the firewall and the engine:
The item in the photo is most certainly an early PCV valve. How early I can't say ........
It's identical to the one on my '63 Plymouth and the one on my Dads '66 Dodge.
........ The first PCV valves were used on WW II tanks ........
Yes, and they looked nothing like the one pictured.
Norm
Old Sep 4, 2008 | 07:15 PM
  #56
PetChemMan's Avatar
Your engine may or may not need a rebuild, but definitely get the stock crankcase breather vent operating normally before you proceed. My '54 Olds started burning oil prematurely, and it turned out to be simply a clogged breather filter. Don't rely on someone's attempted retrofit of a PCV valve to operate correctly, and mislead you. Also be aware that , if your engine has a fuel pump with a booster vacuum pump on top , a broken diaphram in the vacuum pump section can result in crankcase oil getting into the intake manifold, and in some designs even into the gasoline, giving the appearance of your engine burning oil for other reasons. Check out any lines into or out of the vacuum pump for evidence of oil.
blunce
Jul 23, 2014 07:41 PM
ctrain22
Jul 29, 2009 10:46 AM
68Tom
May 24, 2009 12:53 AM
54olds
Apr 10, 2008 01:40 PM
